|  | Home > Maintenance & Mods (L322) > Air conditioner compresor/fan making intermittent squeeling |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825      | Sounds like a worn bearing on the compressor clutch, they will soldier on for ages though, just a bit noisy.... Pete
|  1st May 2015 5:11pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | Drive belt slipping? | ||
|  1st May 2015 5:33pm |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | No idea about drive belt. Iat starts doing it/stops doing it only when the AC is on/off.
|  1st May 2015 5:48pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825      | Will eventually fail but that can take years, if you can find someone to strip and rebuild the compressor then that's the cheapest way, if not it's get a new one time....
|  1st May 2015 6:55pm |
| gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077      | have yet to fix this on mine. i think mine is compressor though, as it sounds ok until i switch the ac on, then it squeals. have brought second hand compressor off a bmw x5 when i get round to it i'll get a local aircon man to come and have a look and try vacuum test first if thats ok it may just need regassing and some oil putting in.
|  1st May 2015 6:56pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825      | Greg, keep meaning to look at mine as the bearing grumbles... can you take the front pulley off with it still on the car, does it just unbolt??
|  1st May 2015 7:06pm |
| gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077      | i havn't tried but have been underneath access is very limited, as i was stuck for time (as usual ) i tried the tensioner first to see if i could release the belt being by the rad i did'nt want to push it and gave up
|  1st May 2015 7:49pm |
| Posting Rules
   must have had one glass toò many see above there is a circlip after the front piece comes off òn the shaft then pulley pulls off.
