Home > Technical (L322) > Lifting a FF on a 2 post lift?
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Hi Folks.
Has anyone got any pointers on lifting a vogue on a 2 post lift?
Is there any settings to put the suspension on as I have heard of
someone busting suspension?
Thanks in advance.
Gary
Post #325387 1st May 2015 5:20pm
Had mine on one loads of times, never had any problems, always comes back to land at the height it was when raised... Pete
-Click here for Thread-
Post #325395 1st May 2015 6:08pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
+1 pete.
read somewhere either hand book or rave, when vehicle is lifted all four wheels off the ground, the suspension will lock out until the wheels are back on the ground. Thumbs Up
Post #325414 1st May 2015 7:31pm
Garyfax
Thanks Guys.
Much appriciated. Better safe than sorry.
Gary
Post #325454 1st May 2015 11:21pm
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
I've lifted ours with no issues. The only thing is to remove the deployable side steps if present, to get access to the lifting points.
 Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #325478 2nd May 2015 8:07am
Why remove deployables??? They stay out with a button sequence sir Whistle
Post #325488 2nd May 2015 8:39am
Edfors
OK, probably possibly with another lift, on our lift the steps will foul the arms of the lift. Guess I could use some taller lift pads. Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #325490 2nd May 2015 8:44am
Ahh now i understand!.. Mine has three different lengths of pad extensions so the arm's are kept well away from deployed steps Thumbs Up
Post #325491 2nd May 2015 8:48am
Garyfax
Yes mine has deployable steps, silly question
but apart from leaving door open is there another
way to keep them out?
Gary
Post #325502 2nd May 2015 9:35am
Is the procedure not in the WIKI?
Post #325504 2nd May 2015 9:47am
Garyfax
What sort of ramp is that Edfors? I have just installed a 4T Automotech in my unit.
Gary
Post #325507 2nd May 2015 9:51am
Garyfax
Thanks Craig I will have a look.
Gary
Post #325508 2nd May 2015 9:54am
Edfors
Nussbaum 3 tonne Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #325509 2nd May 2015 9:54am
