![]() | Home > Technical (L322) > Lifting a FF on a 2 post lift? |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Hi Folks.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Had mine on one loads of times, never had any problems, always comes back to land at the height it was when raised... Pete
Thanks Guys.
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 ![]() ![]() ![]() |
I've lifted ours with no issues. The only thing is to remove the deployable side steps if present, to get access to the lifting points.
Why remove deployables??? They stay out with a button sequence sir |
OK, probably possibly with another lift, on our lift the steps will foul the arms of the lift. Guess I could use some taller lift pads. Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
Ahh now i understand!.. Mine has three different lengths of pad extensions so the arm's are kept well away from deployed steps |
Yes mine has deployable steps, silly question
Is the procedure not in the WIKI? |
What sort of ramp is that Edfors? I have just installed a 4T Automotech in my unit.
Thanks Craig I will have a look.
Nussbaum 3 tonne Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
