Home > Technical (L322) > Handbrake Lever
Mal
2005 Range Rover Autobiography Td6 Java Black
Handbrake Lever
Morning folks,
Going to change the handbrake lever on 05 vogue td6, any advice/tips
cheers
Mal
Post #325473 2nd May 2015 7:12am
Wear thick leather gloves, there's lots of sharp metal in that area Big Cry
Post #325475 2nd May 2015 7:49am
Mal
Cheers, will bear that in mind, but I was looking for a bit more technical advice
Post #325477 2nd May 2015 8:04am
Might want to explain why you are changing it, so as future users with the same issue can use the search function! Without irritating our site mods Whistle Laughing
Post #325489 2nd May 2015 8:41am
Mal
Changing as I have been told by garage that the cable adjuster is not working correctly, I had the handbrake shoes adjusted and handbrake is still crap.
On another note whilst driving on Sunday had a sudden loss of power no lights on dash and its been a bit hit & miss since anybody got any thoughts.
Then this morning driving to work had tranferbox neutral come on the dash
Post #326059 5th May 2015 10:49am
Before doing anything with the handbrake lever and cable have you had the rear drums off?
Mine was similar to yours, took the drums off, cleaned out all the rubbish, emery-papered the shoe surfaces and drum surfaces, put it all back together and the handbrake worked perfectly.
Worth a look.
Post #326063 5th May 2015 11:01am
Mal
Yes all that was done and the shoes adjusted up, the handbrake works but not effectively and I don't think it would go through its MOT as is
Post #326064 5th May 2015 11:08am
Unlucky.
Could just be the cable that needs changed, they do tend to stretch through time.
Post #326068 5th May 2015 11:17am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Does that mean your cable is partly in the future Rolling with laughter Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #326079 5th May 2015 12:35pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I replaced drum & shoes, adjusted, replaced cables. Still useless. Perhaps my adjustment mechanism on lever is knackered. Beware sharp edges and I look forward to hearing how you get on. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #326202 5th May 2015 10:35pm
Have you tried it at different suspension heights? Due to the extreme articulation your handbrake can work well on off road height... Drop it to access height and your handbrake probably won’t hold the car at all! Thumbs Up
Post #326210 5th May 2015 11:16pm
Mal
Have not tried that, but would have thought that the handbrake should work in all situations. No doubt I will have to replace the cables as well.
Post #326239 6th May 2015 6:30am
There is a reason they changed to an elec handbrake sir Whistle Whistle Whistle
Post #326277 6th May 2015 9:42am
Mal
Apparently that's worse most people I have spoken to reckon it always goes wrong and about a grand a pop to fix. Will stick to mechanical thank you sir
Post #326279 6th May 2015 9:55am
