![]() | Home > Maintenance & Mods (L322) > issues with my 2003 4.4 v8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8722 ![]() ![]() ![]() |
I don't think new discs will sort out a sticking caliper...
bag 933s Member Since: 21 Apr 2015 Location: south west Posts: 13 ![]() ![]() ![]() |
hi pete, i have bought the new discs as one side is badly scored so when i have them stripped down ect i can just fit new parts, its the main fan at front of engine...... |
i have read so much on the lumpy running, i cant say its miss firing, i heard could be torque converter, coil packs ect, its just at that speed you wsnt to cruise on the motorway also, has anyone else encountered this? |
it has a full service history 104,000 and i had it fully serviced before purchase |
I'd start with a full 4 wheel laser alignment and wheel balance and take it from there...
thought i would update this, new discs and pads fitted to the rear, we managed to find the cause of the irritating wobble when driving, it was 4 x 5mm cast spacers one on each wheel......had the mot done straight through and no advisories |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
If you're talking about the fan 'inside' the engine bay, then this is a viscous fan, it spins all the time. However with the engine off and a cold engine you should be able to turn the fan freely by hand. When the viscous clutch in the hub gets hot it locks up and drives the fan harder.
