Home > Maintenance & Mods (L322) > issues with my 2003 4.4 v8
bag 933s
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
well im not letting this RR beat me, been spot on since i purchased her, although i noticed i sticking caliper i ordered a set of rear discs ect, so am hoping this will sort out the wobble through the steering wheel at around 55-70 if not i shall be getting tracking and balancing done, but have noticed now when i start her the fan comes on straight away, is this normal? and im sure i heard a knock on start up....or its me getting paranoid its just the little niggles that are causing concern
Post #325599 2nd May 2015 9:56pm
I don't think new discs will sort out a sticking caliper...
What fan are you talking about, heater, engine or aircon?? Pete
Post #325604 2nd May 2015 10:01pm
bag 933s
hi pete, i have bought the new discs as one side is badly scored so when i have them stripped down ect i can just fit new parts, its the main fan at front of engine......
Post #325605 2nd May 2015 10:06pm
bag 933s
i have read so much on the lumpy running, i cant say its miss firing, i heard could be torque converter, coil packs ect, its just at that speed you wsnt to cruise on the motorway also, has anyone else encountered this?
Post #325606 2nd May 2015 10:08pm
bag 933s
it has a full service history 104,000 and i had it fully serviced before purchase
Post #325607 2nd May 2015 10:09pm
I'd start with a full 4 wheel laser alignment and wheel balance and take it from there...
What fan are you talking about?? Pete
Post #325612 2nd May 2015 10:41pm
bag 933s
thought i would update this, new discs and pads fitted to the rear, we managed to find the cause of the irritating wobble when driving, it was 4 x 5mm cast spacers one on each wheel......had the mot done straight through and no advisories
Post #329292 24th May 2015 4:39pm
Zirconblue
If you're talking about the fan 'inside' the engine bay, then this is a viscous fan, it spins all the time. However with the engine off and a cold engine you should be able to turn the fan freely by hand. When the viscous clutch in the hub gets hot it locks up and drives the fan harder.
If you cant turn the fan easily by hand when it's cold, then the viscous clutch is seized.
Post #329303 24th May 2015 7:04pm
