![]() | Home > My Range Rover > 2002 L322 Java black - photos |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Welcome.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Very nice. |
Thanks for the likes...
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
Android head unit is great, there is a write up in the WIKI Scraping on turning could be a lip on the edge of the brake discs Do the diffs and transfer box as well, only use the correct oil from the dealer No drain plug on engine... just on the bottom of the rad Not sure about the lights... you would need the whole unit and the starters for the bulbs, be pretty expensive... Nice looking FF.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
@ haylands... thanks. About coolant the flush: I recently tried it, by loosening the lowest hose from the radiator, but I only gathered about 8 liters from it (I did unscrew the fill cap and bleeding screw on top of the tank). The manual says I should get about 17 liters, so my best guess was that there should be a drain plug underneath the engine...
Says it takes 17 ltrs, not that you can get 17ltrs out!! I just back flushed mine with a hosepipe through every pipe I could find till it ran clear, fitted them all back and filled up with neat antifreeze... Pete
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Pieter, I was born in Amsterdam living in SW of France now from 2000 on. Yep only 3 of us, You, Eugene (somewhere in the far east at the moment) and me. That's it.
@ haylands: manual says I should get about 13 Liters out for a refill... I was near to 8 liters... MAybe I should backflush it, as you did.... RAVE does speak about an engine drain plug though.... Step 8 and nine... http://workshop-manuals.com/landrover/l322...p;_refill/
Hmm, never spotted that, that's on your passenger side just in front of the starter motor, be a right pain to get to... Pete
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
Very nice looking car, i have one almost exactly the same |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
Niet helemaal juist, ik ben hier ook, en all heeeeeeeeeeeeel lang, sinds oprichting. Was eerst op RangeRover.net, en daarna hier |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
I want to know this too. |
@starberg @chex: I ordered a new key here: http://www.ecuobd2.com/trk-land-07-433. I then took this to my local locksmith to copy/cut my old-style BMW key into the new key. I then took the chip out of the old key and placed it into my new key... No need to re-learn the new key to the car because you are using your old chip. Pretty easy to do and the new key looks so much better...
