Home > My Range Rover > 2002 L322 Java black - photos
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Hi forum,
Wanting to introduce my new 2002 l322. I've got her since dec. 14 and am very - very pleased with her. Previous cars were Jags (xj6 and xj8). So this is something totally different. Had to get used to the seats which are, IMHO, a bit stiff compared to the Jags.
155.000 km when I bought her...
Already have the following changed/fixed:
- LHF air stud, replaced by a remanufactured Arnott's. Very pleased with it.
- Changed thermostat, wouldn't open on the highway causing one of the upper coolant hoses to pop off... Thought I caught a fire there...
- changed the orange side indicators to smoked glass
- Fixed passenger cup holder, wouldn't open... the fix was to remove the cupholder from the dashboard and heat the back of the cupholder, then carefully bending the back out a bit.... Now it works like a charm.
- changed the old-style key to a new style flip key (see photo)
- When I bought her, not all LED's of the RH brake light would come on (in fact only three). Fixed it by removing the old and soldering a new diode to the printscreen, very easy job.
- changed motoroil and various filters
- Changed window trim (was bubbling)
- Changed green LR badges for black ones
Wanting to change/fix the following:
- Replace old head-unit with Android Head unit
- I can feel a very light scraping (do not hear it) when steering to the left, should I replace the track-rod end?
- Steering wheel is off-centre, probably should do a wheel alignment
- Window tinting
- Change differential oil
- Want to do a coolant flush, but I can't find the drain plug off the engine.
- Replace the halogen front lights with Xenon lights (is it just plug and play?)
Ok... 'Nough said.... Time for some photo's...
Post #325741 3rd May 2015 2:52pm
mjdronfield
Welcome.
Looks very nice.
I do like the look of the early ones, but then I'm a bit biased !
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #325745 3rd May 2015 3:19pm
Weegie
Very nice. Thumbs Up What size are the wheels? Don't spend too much time so close to the sea!Wink John
GAP iiD BT-Sold
Post #325746 3rd May 2015 3:31pm
pietertje
Thanks for the likes...
@ Weegie: I suppose they are standard 19".... About the sea, good advice Smile But sometimes I just can't resist the temptation....
Post #325747 3rd May 2015 3:35pm
Re: 2002 L322 Java black - photos
- Window tinting
Android head unit is great, there is a write up in the WIKI
Scraping on turning could be a lip on the edge of the brake discs
Do the diffs and transfer box as well, only use the correct oil from the dealer
No drain plug on engine... just on the bottom of the rad
Not sure about the lights... you would need the whole unit and the starters for the bulbs, be pretty expensive...
Nice looking FF.... Pete
Post #325751 3rd May 2015 4:13pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi, finally an other Dutchman, think we're 3 of us now on here, so "Welkom"
Heb ook nog een 02 staan in de garage, fijne auto! Betere stoelen dan in mijn 07
This is a great place to be, humour, serious help and a bundle of knowledge.
Enjoy the fulfat!
Post #325762 3rd May 2015 4:33pm
pietertje
@ haylands... thanks. About coolant the flush: I recently tried it, by loosening the lowest hose from the radiator, but I only gathered about 8 liters from it (I did unscrew the fill cap and bleeding screw on top of the tank). The manual says I should get about 17 liters, so my best guess was that there should be a drain plug underneath the engine...
Saw your write up of the Anroid Unit. Will definitely come in handy when I plan mine...
@ Robert, dankjewel! Only three of us Nederlanders? I had expected it to be more.. So from what region are you???
Post #325767 3rd May 2015 4:42pm
Says it takes 17 ltrs, not that you can get 17ltrs out!! I just back flushed mine with a hosepipe through every pipe I could find till it ran clear, fitted them all back and filled up with neat antifreeze... Pete
Post #325769 3rd May 2015 4:47pm
Robert
Pieter, I was born in Amsterdam living in SW of France now from 2000 on. Yep only 3 of us, You, Eugene (somewhere in the far east at the moment) and me. That's it.
The pic from the engine was just taken from my 02 where I took the top of to see what's in the down under. I'm not a tech, not at all. Embarassed
Post #325785 3rd May 2015 5:29pm
pietertje
@ haylands: manual says I should get about 13 Liters out for a refill... I was near to 8 liters... MAybe I should backflush it, as you did.... RAVE does speak about an engine drain plug though.... Step 8 and nine... http://workshop-manuals.com/landrover/l322...p;_refill/
@ Robert, neither am I. But with the help of this great forum and some common sense I hope to do a lot of the maintenance and repairs myself. Thanks for your photo!
Post #325795 3rd May 2015 6:12pm
Hmm, never spotted that, that's on your passenger side just in front of the starter motor, be a right pain to get to... Pete
Post #325799 3rd May 2015 6:17pm
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
Very nice looking car, i have one almost exactly the same Smile
How did you change the old key to the new flip key style if i may ask? L322 Vogue 2003
Post #325855 3rd May 2015 8:42pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Niet helemaal juist, ik ben hier ook, en all heeeeeeeeeeeeel lang, sinds oprichting. Was eerst op RangeRover.net, en daarna hier
Post #325858 3rd May 2015 8:48pm
chex
Kenya
I want to know this too.
Post #325863 3rd May 2015 9:18pm
pietertje
@starberg @chex: I ordered a new key here: http://www.ecuobd2.com/trk-land-07-433. I then took this to my local locksmith to copy/cut my old-style BMW key into the new key. I then took the chip out of the old key and placed it into my new key... No need to re-learn the new key to the car because you are using your old chip. Pretty easy to do and the new key looks so much better...
To finish the look I ordered these car tire valves http://nl.aliexpress.com/item/Theftproof-S...80507.html took the Range Rover logo off and superglued it onto the new key... 2002 L322 V8
Post #325895 4th May 2015 12:06am
