|  | Home > General (L405) > Knocking Update |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698    | I'd tell them to shove their car!
|  4th Aug 2014 3:51pm |
| chris_j_g Member Since: 12 Dec 2008 Location: Bristol Posts: 4      | I heard from my dealer yesterday that there is now a TSB released for the knocking issue, it does include replacing this valve that appears to fix the problem, there is a lead time on the delivery of part but lets hope this finally resolves it. | ||
|  14th Aug 2014 6:39am |
| Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127    | Mine's been done, but need to do some reasonable mileage before passing judgement on the success.
|  14th Aug 2014 7:45am |
| Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127    | New valve block fitted and system re-programmed one month ago and so far seems fine. Just the very odd faint knock on rough surface. So now much better to drive and live with.
|  6th Sep 2014 10:04am |
| CaptainG Member Since: 16 Dec 2013 Location: Bristol Posts: 13      | Mine is in today so hoping they will replace this valve as its had every other mod, I did say I dont want it back unless they do. Have been told it will take 3 days to sort it, I await the possibility of a quiet ride... | ||
|  8th Sep 2014 9:46am |
| modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237      |
|  8th Sep 2014 2:13pm |
| CaptainG Member Since: 16 Dec 2013 Location: Bristol Posts: 13      | I was surprised it was 3 days, apparently first day was for other checks before LR would release part,
|  11th Sep 2014 1:42pm |
| jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229      | Just had my SDV8 in for the knocking again the bulletin this time was to replace the steering rack bolts and control arm bushes. This has made a bit of improvement in steering feel but knock is still there.
|  23rd Apr 2015 5:08am |
| 5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 721    | Unless they replace the Valve block with one with dampers the rest of what they are doing is likely to be a waste of time. Mine has been fine ever since I had this done. | ||
|  23rd Apr 2015 10:52am |
| jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229      | Well the knock is still there! The dealer is now replacing the whole steering rack. I did mention your advise on ARC Valve!
|  3rd May 2015 1:22am |
| Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127    | 5.0 is right.
|  3rd May 2015 3:34pm |
| DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69      | If I get the knock only going over bumps and holes in the road, is that still the issue being discussed here ?
|  3rd May 2015 8:57pm |
| Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127    | If it's the SDV6 it's ok as it does not have this roll control system.
|  4th May 2015 8:45am |
| jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229      | Danger mouse the knock is on rough surfaces or pot holes or sharp bumps in the road. I have just got the car back with the replacement steering rack  plus the ARC was replaced earlier .
|  5th May 2015 6:21am |
| Posting Rules
 hope goes well.  but three days?
 hope goes well.  but three days?  mine in/out same day! inc full valet..
