Home > Maintenance & Mods (L322) > Trickle Charging
n1cktdv8
Trickle Charging
My Rangey gets very little use and after a recent stint of sitting on the drive; boot open, closed, open closed while we get things from it once again it was dead as a dodo...
Friend on D3 forum recommends a C-Tek charger with a 13pin socket set up that will allow a trickle charge.
As it's doing not much mileage is this an option or am I masking a deeper problem. Last time battery flat my auto-elec mate couldn't find a direct issue.
I have a decent Ring digital 16A charger but the thought of upping the bonnet and lifting a 110Ah Bosch S5 every month for a "top up" isn't thrilling me, a plug in option however is.
Thoughts Peeps
Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #326251 6th May 2015 8:44am
Nick, the C-Tek charger is indeed a good idea in any FFRR especially if not used on a daily basis Thumbs Up
Secondly, After someone on the forum raved over the prices of the Bosch S5 batteries and many members went out and bought them, I have found most fitted to TDV8’s i look after have been failing much like yours... Changed a few on customers cars 2 or 3 times under the Bosch guarantee, but in the end inevitably they all go the same way...
Just my findings Nick Thumbs Up
Post #326255 6th May 2015 8:53am
n1cktdv8
Morning Sir Thumbs Up
Yes, I did jump on that bandwagon (in fairness my LR one failed and turned out to be the original '07) and yes I too have had one exchanged under warranty.
If there is a simple plug and play C-Tek then I'll most likely go for that. I can't find it over on D3 just now but am sure someone knows.
With all the electronicals on board it's a big ask to draw all that and then expect a week later to turn over in one hit.
My S5 was on charge last night, fitted this morning and started first time very strongly. Is this where I put the car details and a bit about myself ?........
Post #326257 6th May 2015 8:58am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I've just ordered a CTEK 7 as I wanted the supply option.
Will also be ordering a tow socket adapter from the FFRR Shop as well, that saves bu***ing about with bonnets etc.
Cheers
Steve
Post #326259 6th May 2015 9:06am
Is this what your looking for Nick?
http://www.disco3.co.uk/shop/tow-electrics...c-p45.html
Post #326261 6th May 2015 9:11am
n1cktdv8
Thanks, thats the one Craig. Bit of study time now and we'll see what I come up with Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #326269 6th May 2015 9:33am
Post #326275 6th May 2015 9:39am
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
i use a solar panel on my caravan to keep that topped up, might be an idea to do the same for the RR.
Post #326281 6th May 2015 10:00am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I use a Ctek 5 as like the 7 has the pulse charge function. I purchased an extension lead which is permanently fitted to the batt terminals and (being 2m long) can simply be attached to the Ctek in the garage. Bonnet can also be locked back shut again.
Naturally this is best with a garaged car but works well.
Cteks are well made and seem good quality products.
I also need to make sure I'm not forgetting and reversing out of the garage!!!
 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #326332 6th May 2015 1:47pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Used c teks for ages on classics and on the FF, saves a lot of batteries and car is always ready to go ( if you don't forget to take them out and drive along with the cables hanging out of the car.... Embarassed )
Post #326333 6th May 2015 2:03pm
bebechoon
France
I use a Ring Automotive RSP600 Solar Maintainer (6A), which I bought for about £40 from amazing co uk, plugged into the front or boot cigar lighter socket (which are live all the time). It seems to keep my FF battery in a very healthy charge state. Thumbs Up
But it’s sunny down here Very Happy – dunno how good it’d be in the UK. It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 8 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #326354 6th May 2015 3:20pm
havnt used mine for over 11 days ,started first time today, mind you it is a petrol.. Mr. Green ... - .- -.
Post #326356 6th May 2015 3:27pm
n1cktdv8
Foxtrot Oscar Mr Moderator Whistle Is this where I put the car details and a bit about myself ?........
Post #326359 6th May 2015 4:06pm
bebechoon
France
May one ask WHY you haven't used yours for 11days, Stan? Oh ... it's a petrol. That's why - you can't afford it! Rolling with laughter It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #326360 6th May 2015 4:11pm
damn you sir , i challenge you to fuel pump handles at dawn.. Laughing ... - .- -.
Post #326361 6th May 2015 4:16pm
