![]() | Home > Maintenance & Mods (L322) > How to prevent matt steering wheel leather going shiny |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Bizarrely enough Tim i thought the same thing the other day... I fitted a brand new wheel to my car some months ago and the same thing as yours started happening to mine! So, the other day i cleaned my wheel using a “flash fabreas” multi surface cleaner my wife uses and......... “Voila” immediately back to matte again.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
Perspiration or natural oils from hands rather than actual dirt?. John
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
^ most likely... ... - .- -.
trickymickey Member Since: 28 Mar 2014 Location: Worksop Posts: 46 ![]() ![]() ![]() |
I use Gliptone leather cleaner , and then finish with Gliptones conditioner on my wheel . Seems to do the trick and smells glorious ! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
One of these should solve the problem:
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Hi I always understand early shine on steering wheels is down to dirt and sweat. Wipe regulary with a micro fibre cloth and hot water this seems to return the wheel back to matt and like new. On older steering wheels it is the leather it self which has 'shined' up and therefore you are limited to what can be done.(keep wheels clean and they don't shine up !)
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
exactly as said above. a friend used to swear by very weak APC (all purpose cleaner) cleaned off with a damp cloth. once the greasy layer is on and the leather shined up even a TFR will only work for a few days.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
PVC Frame solvent cleaner will make it dull again |
Good shout... |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Best product I have ever used : Leather Ultra Clean (diluted 50% with water). does exactly what you (and I) wanted.
