Home > Technical (L322) > What size hub nut
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
What size hub nut
After some help please fella's,
I have a broken spring on the hand brake (off side) so need to get the hub off, what size is the nut and torque setting.
rear disc/drum was squealing, I have backed the shoes off and got the retain spring out.
I did read on another thread somewhere it was 38 mm? And set at 420lbs, that's flippin tight Big Cry is this correct? If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #327010 10th May 2015 10:46am
Why do you need to remove the hub nut? rear disc is held in place by an allen screw in the disc face. This will release the disc/drum and give access to the springs and handbrake cable assembly at the top of the hub. .
Post #327026 10th May 2015 2:01pm
Welshdragon
Confused
Ok going to have a look now again!
Thanks Tim Thumbs Up If it dont work.......burn it!
Post #327032 10th May 2015 2:21pm
Welshdragon
Must of had a brain fart Laughing . ... I blame me been on nightshift last night !
Disc off and temporary repair done till new shields bought as they are pretty rusty Big Cry
Thanks Tim for the info, oue you a beer for that....was looking at getting some tools Laughing Embarassed If it dont work.......burn it!
Post #327042 10th May 2015 3:48pm
Need to release the hub nut, remove hub to renew brake backplate believe it or not!!! Shocked Shocked Shocked
Lot of work for a posy bit of tin!!! Rolling Eyes
Post #327044 10th May 2015 4:06pm
Welshdragon
Do you Craig, didn't look like it from what I was look at it earlier Big Cry
If that's the case it looks like the temporary repair may be long term fix Laughing If it dont work.......burn it!
Post #327047 10th May 2015 4:31pm
The backplate is a solid round unit that bolts/fixes in such a way you need to remove lots to fit WD!
Post #327049 10th May 2015 4:40pm
Welshdragon
Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
Good old LR ....they have never learnt to do simple jobs easy have they.
Still need an new socket then to do the job. Crying or Very sad
Thanks Craig Thumbs Up If it dont work.......burn it!
Post #327055 10th May 2015 4:57pm
Too much work involved in changing the backplate, have a read here
Post #327058 10th May 2015 5:25pm
^^^ for fixing/sorting the holes ( I just used some washers)
This for removing/refitting backplates/splashguards without removing hub
http://www.fullfatrr.com/forum/topic18371.html?highlight=splash
http://www.fullfatrr.com/gallery/thumbnails.php?album=714
A lot of peoples do this with the new ones, due to the hassle Whistle .
Post #327070 10th May 2015 6:44pm
Welshdragon
Mrs WD is bring some of them springs home from work later that are used on there cars to see if they do the job.
My washer temp repair is good enough but the other spring on same side is well and truly foobared.
New disc shields are now 50 quid .....Each! Shocked
(Thanks sir Dan for the quick reply this morning but going to ...err leave them on the shelf ) If it dont work.......burn it!
Post #327199 11th May 2015 4:15pm
