![]() | Home > In Car Electronics (L322) > Poor FM reception L322 2007 TDV8 Vogue SOLVED |
| Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232
As above only started this morning, symptoms are same as weak signal, hissing in background and noisy, LW and MW are fine, checked for damp & poor connections under tailgate trim panel all o/k, nice & dry, gave everything a bit of a wiggle but not making any difference so suspect one of the aerial amplifiers, problem is as far as I can see there are three, one on left hand side of tailgate, & one in o/s & n/s rear wings, anyone have any idea which one does what and which one is the likely culprit, not keen on buying all three if it might be something else, help required |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Check the aerial connections including amplifier modules etc on all 3 boot windows. Modules high up in the boot side compartments too. A sure fire way of telling is to listen to the radio and turn the heated rear window on. If it makes a difference then it's definitely a connector gone high resistance. I spent almost a whole day fixing this on my old 07 Vogue SE. Most irritating. |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
First do a battery reset, if that does not work listen to a CD for a week, just in case its either a transmitter fault in your area or a gremlin in your FF that may well fix itself after a week of CD listening sir |
Heated rear window on or off makes no difference, thinking it's probably one of amplifiers but which one |
Found this page which helps a bit, however no description for item 10, says 2 is FM amplifier so thinking to start there. anyone know what item 10 is |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
answer is probably on page 780.. ... - .- -.
Strange, page 780 no help at all |
there you go,
That's the one I need, different page from mine, think we were looking in different places, now which one to change first |
0/k changed both FM aerial amps and no different, losing the will to live now |
do you defo have power going to these amps? ... - .- -.
Yep, power to amps, not too sure what to try next |
i suppose the earth points and the antenna cable .. ... - .- -.
Been there done that, not sure where the antenna cable goes after the amps, think the tuner is in rear quarter so next step might be there, just seems like the FM aerial is unplugged from somewhere as FM is only picking up strong signals and AM and TV are fine |
