Home > In Car Electronics (L322) > Poor FM reception L322 2007 TDV8 Vogue SOLVED
Robgosty
As above only started this morning, symptoms are same as weak signal, hissing in background and noisy, LW and MW are fine, checked for damp & poor connections under tailgate trim panel all o/k, nice & dry, gave everything a bit of a wiggle but not making any difference so suspect one of the aerial amplifiers, problem is as far as I can see there are three, one on left hand side of tailgate, & one in o/s & n/s rear wings, anyone have any idea which one does what and which one is the likely culprit, not keen on buying all three if it might be something else, help required Big Cry Banging Head
Post #327065 10th May 2015 6:55pm
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
Strangely enough mine was in with the supplying dealer for four weeks recently, one item being the rear washer only a minor item the return valve but one the way back and on my drive to Sunbury from Portsmouth the reception was terrible, thought in stripping out the rear spoiler or that area they may have disturbed the ariel connection. I know approximately where I will loose the London stations coming back and need to jump to another station but now I can only just get to Guildford past the M25 and signal comes and goes all fuzzy, even local stations on and off can be fuzzy. It is going back as a number of items confirmed 'on the phone' as complete were not even touched.
If anything is found will let you know. Porsche 993 Targa, Buick Skylark Convertable 1968
Post #327074 10th May 2015 8:02pm
mzplcg
Check the aerial connections including amplifier modules etc on all 3 boot windows. Modules high up in the boot side compartments too. A sure fire way of telling is to listen to the radio and turn the heated rear window on. If it makes a difference then it's definitely a connector gone high resistance. I spent almost a whole day fixing this on my old 07 Vogue SE. Most irritating.
Post #327116 11th May 2015 8:42am
First do a battery reset, if that does not work listen to a CD for a week, just in case its either a transmitter fault in your area or a gremlin in your FF that may well fix itself after a week of CD listening sir Whistle Whistle Whistle Thumbs Up
Post #327123 11th May 2015 8:57am
Robgosty
Heated rear window on or off makes no difference, thinking it's probably one of amplifiers but which one Banging Head
Post #327132 11th May 2015 9:38am
Robgosty
Found this page which helps a bit, however no description for item 10, says 2 is FM amplifier so thinking to start there. anyone know what item 10 is Sad
http://workshop-manuals.com/landrover/l322.../page_749/
Post #327160 11th May 2015 12:49pm
answer is probably on page 780.. ... - .- -.
Post #327165 11th May 2015 1:12pm
Robgosty
Strange, page 780 no help at all
Post #327168 11th May 2015 1:22pm
there you go,
Post #327170 11th May 2015 1:24pm
Robgosty
That's the one I need, different page from mine, think we were looking in different places, now which one to change first Big Cry
Post #327174 11th May 2015 1:38pm
Robgosty
0/k changed both FM aerial amps and no different, losing the will to live now Big Cry
Post #328061 15th May 2015 1:55pm
do you defo have power going to these amps? ... - .- -.
Post #328065 15th May 2015 2:50pm
Robgosty
Yep, power to amps, not too sure what to try next Sad
Post #328077 15th May 2015 4:23pm
i suppose the earth points and the antenna cable .. ... - .- -.
Post #328088 15th May 2015 5:54pm
Robgosty
Been there done that, not sure where the antenna cable goes after the amps, think the tuner is in rear quarter so next step might be there, just seems like the FM aerial is unplugged from somewhere as FM is only picking up strong signals and AM and TV are fine Banging Head Banging Head
Post #328103 15th May 2015 7:36pm
