Home > Technical (L322) > Door latch mechanism
Tom Paine
Australia 2003 Range Rover HSE Td6 Bonatti Grey
I was replacing the passenger door mirror when the door latch disconnected itself. How on earth do I reconnect it?
Post #327315 12th May 2015 6:43am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Exterior or Interior latch?
Whichever one it is it'll require the removal of the door card.
You'll probably find one of the cables/connecting rods has popped out.
Latch removal and refit here:
http://workshop-manuals.com/landrover/l322...ront_door/
Post #327364 12th May 2015 10:31am
Tom Paine
It's the connection from the door itself to the inside of the card. There's a sort of curving plastic fork that need to be connected up to the inside door release, but how?
Post #327368 12th May 2015 10:44am
the cable end hooks into the curved plastic thingy though its a bit fiddly .. ... - .- -.
Post #327369 12th May 2015 10:50am
Tom Paine
I was afraid it was something like that. Do I need teeny-weeny hands as well?
Post #327371 12th May 2015 10:52am
not really just need to hold the door card up whilst connecting the cable.. ... - .- -.
Post #327372 12th May 2015 10:58am
Tom Paine
Right. Tomorrow we shall set about it. Thanks.
Post #327373 12th May 2015 11:02am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
As Stan said it's just a but juggly. support the door card and you should have enough play- I managed it with my shovel hands! Laughing
Post #327394 12th May 2015 12:16pm
miggit
When the cable on the outer door handle snapped I had to remove the door card, followed Rave to the picture / letter, and then it said pull the card away from the door, so I did, and the inner cable pinged off Banging Head Banging Head
What it should have read was gentaly ease the card away from the door so that you can release the inner door handle and see how it's fixed, Censored L/R, think I'm a spotty tech with enough strength to operate a keyboard, pull means yank not tease Censored Censored
Anyway it soon became apparent how it went together, only you do have to hold the card about 2" from the door so it's tight, but doable Thumbs Up
Ps check that it works before you clip the card back on, I wouldn't want you to have a Banging Head Banging Head Thud Censored Censored moment Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #327581 12th May 2015 10:52pm
Weejock
And once you've mastered removing the door card you can check to make sure the key opens the drivers door. The rod can become disconnected inside which is fairly common (mine had). You'll be glad you did when you come back to a flat battery one day or your remote has lost it's sync!
Post #327672 13th May 2015 1:58pm
