![]() | Home > Technical (L322) > Door latch mechanism |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Exterior or Interior latch?
Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47 ![]() ![]() ![]() |
It's the connection from the door itself to the inside of the card. There's a sort of curving plastic fork that need to be connected up to the inside door release, but how? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
the cable end hooks into the curved plastic thingy though its a bit fiddly .. ... - .- -.
I was afraid it was something like that. Do I need teeny-weeny hands as well? |
not really just need to hold the door card up whilst connecting the cable.. ... - .- -.
Right. Tomorrow we shall set about it. Thanks. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
As Stan said it's just a but juggly. support the door card and you should have enough play- I managed it with my shovel hands! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
When the cable on the outer door handle snapped I had to remove the door card, followed Rave to the picture / letter, and then it said pull the card away from the door, so I did, and the inner cable pinged off |
And once you've mastered removing the door card you can check to make sure the key opens the drivers door. The rod can become disconnected inside which is fairly common (mine had). You'll be glad you did when you come back to a flat battery one day or your remote has lost it's sync! |
