![]() | Home > Technical (L322) > Sump plug won't come out |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Craig, it appears to have a sprung loaded catch, so it should require more than a knock, the sump cover will also stop you coming in to contact (I think, not too familiar with bowls of the beast ), and what sort of Muppet is going to thrash around under the drain tap that they have fitted ? Surly that's asking for it ?
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
The plug is tight wealy, I wouldn't even consider it if it wasn't as I don't want to be in a world of |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
I have used these valves in various sizes over the years on industrial engines, generators etc and the are a quality addition to the servicing routine. Rest assured it would not be possible to open one of these accidentally as they have a very positive spring loaded trigger action before they can be opened. Agueroooooooooo. 93-20
Craig, I'm getting too old to be crawling under cars every five minutes, if I had access to a ramp then it would be a different story. Although a ramp is not that necessary on my Jeep, as you can crawl under the gearbox without jacking it up, it has a good 18" clearance in the middle |
I would be very nervous to use them without first hand feedback. Thanks for that Pfazz |
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 ![]() ![]() ![]() |
Having just changed the oil and filter for the first time since I bought my FFRR in April, I too have found the sump plug has partially stripped the threads from the sump. The PO used to have the car serviced by a (local to him) LR "specialist" who seems to have used PTFE tape on the threads to help seal the plug which is the original RR/BMW plug.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
hat looks well & truly f******d.
Zambezi, buddy, |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1582 ![]() ![]() |
A very late update to this. I will have to fix mine. Take the lower sump off - it is very easy to remove - then you can easily drill and tap out the hole for a Helicoil or for the valve mentioned earlier.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
The standard sump plugs are short putting a lot of strain on a few threads but you can get sump bolts with a longer thread as the thread in the pan is quite deep but that may already have been ruined. I drilled my old thread out and helicoiled it but you have to make sure you drill it square to the sealing face.
I've been thinking how to accurately drill and tap the hole square to the sealing face.
I didn't measure the length of the thread on the plug. From memory, probably not more than 12mm. There's quite a bit of untouched thread left. I was at a friend's rural property and we couldn't find a bolt to replace the plug. It was a bit of hike into town to get a bolt or another plug so we used Teflon tape and screwed it in. I put silicone rubber around the outside to (a) further seal it and (b) to help stop the plug unscrewing.
Just found this.. https://www.ebay.co.uk/itm/BMW-Magnetic-En...0005.m1851
