![]() | Home > Technical (L322) > Trans fail safe prog :( |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
have a read here,
| Slow Member Since: 09 May 2015 Location: Inverness Posts: 39
I have done, just asking in case anyone has personal experience of any of this. |
| ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355
Sounds like the start of a scrap battery to me
| Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223
^+1 low voltage from battery probably the cause SDV8 AB MY 2019
Fitted this big thing, 110ah and 920 cca I believe.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
That baby should sort it, it's amasing the faults you get with low voltage, check the GPS DVD in the boot switches off, they are a known problem, open the rear passenger side compartment, shut the boot and lock the car, the red light on it should go out after about 16minutes, if it doesn't it will drain the battery... also the FSR can drain the battery, have a look in the WIKI for details...
What oil and how much do I need to change it? A Land Rover mechanic told me that you can only half change the oil or something? |
| All times are GMT |
