![]() | Home > Maintenance & Mods (L322) > Td6 exhaust upgrade |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7975 ![]() ![]() ![]() |
I understand if you decat it, it smells like an old ice cream van if you are near the exhaust.
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 ![]() ![]() |
Problem with a diesel is that it will still sound like a tractor , even if in this case a Chelsea tractor ...... Jaybear
Can't hear my Chelsea tractor, as I have had the amp upgrade done and like my music |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
De cats make them stink, sitting in traffic with the windows down is vile.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
And if you De cat it you'll have mot issues un less you swap it back every time |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Actually my mate put a performance exhaust on his TDi Seat. It had no cat or silencer boxes in it. It's wasn't noisy at all! All you heard was a bit more turbo whistle.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1850 ![]() ![]() |
Mine passed its MOT without a cat this morning ![]() |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
IMO on a TD6 it is just not worth the effort or the expense.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16387 ![]() ![]() ![]() |
TD6 will stink without a CAT sir... A younger customer of mine had it done and it slowly smokes everything out!!! ![]() |
It will still pass the emissions test without one. However the tester is also supposed to visually check to see if a Cat is present, if the car had one when new. So it depends if he or she notices. You can also get decats that look the same as a real Catalytic converter, the tester can't check the inside. |
