Home > Maintenance & Mods (L322) > Westfalia Clunkety-clunk!
elandri
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Have recently fitted a Westfalia armature & farmers hitch (after reading many stories of the "detachable ones- detaching) with pin & clip.
All good except for the awful clunking noise on anything remotely bumpy. It seems strange that they designed a towbar with such a lot of slack in it that the serenity of the RR ride is so compromised.
Can anything be done about it? I'm seriously thinking of throwing it away and fitting a Witter fixed jobby!
Post #329791 28th May 2015 2:21pm
mzplcg
Tighten the retaining bolt to the correct torque which will pull the sides of the socket in a little and remove any play. I had the same thing and when I checked the torque figure it resulted in almost a superhuman effort to get it tight enough. All quiet after that.
Post #329792 28th May 2015 2:29pm
There are 3 slightly different versions - one has a pin, one has a bolt and the third has a bolt and is partially threaded too.
Do a search, someone recently added some plastic wedges that seemed to do the trick.
Depends on whether you're leaving it permanently fitted or whether you want it easy to remove
Post #329802 28th May 2015 3:32pm
elandri
Thanks for replies.
As stated in OP I have the pin & clip and would like to retain the ability to remove the ball when tin tent absent.
Found the thread mentioned here:
http://www.fullfatrr.com/forum/topic2805.h...ch+plastic
A few potential workarounds which I'll try over the next few trips out.
Thanks again.
Post #329805 28th May 2015 4:03pm
The threaded one is the quietest, but clearly the more painful to remove -
I also had one with a pin & it rattled a bit, but not enough to bother me - IIRC, the fit was quite tight, but something like these may do the trick.
Good luck Thumbs Up
Post #329815 28th May 2015 5:12pm
Zirconblue
Re: Westfalia Clunkety-clunk!
Not really, you wouldn't be too bothered about it with a rattly old cattle trailer on the back. It's still more serene than a Defender with an adjustable drop plate on it.
Wrap a bit of gaffer tape around the end of it before you jamb it in, that should be enough to take the slack out.
Post #329828 28th May 2015 6:05pm
Or get the removable ball and socket set. Which fit into the same hole in the armature. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #329857 28th May 2015 8:41pm
elandri
Alistair - Great pics. I've googled to try to find a threaded version for sale but come up short. Perhaps I'll give Westfalia a ring.
Short term I can try the gaffer tape/plastic workarounds. Towing weekend after next so not long to wait to see how they go.
NMJ see OP re detachable version.
Thanks to all for help.
Post #331702 9th Jun 2015 7:18pm
Zirconblue
The removable ones are also ugly, as you only remove half of it. They leave a big lump sticking out underneath.
Post #331709 9th Jun 2015 8:03pm
Zirconblue
Actually if you wanted to leave it in there permanently, you could just slather the thing in silicone sealant and push it in, before doing the same with the pin. I would imagine that'll do it.
Post #331710 9th Jun 2015 8:06pm
supershuttle
Took mine off today I didn't realise how much noise it made rattling about. Maybe that's why it's so easy to take off when not in use, I might do it more often Very Happy Geoff
Post #331720 9th Jun 2015 8:26pm
Never read anything about them detaching personally. Big Cry or had a problem personally. Agree though the by left in can be a bit ugly from the back. There is nothing that can't be fixed with a hammer😜😜
Post #331723 9th Jun 2015 8:38pm
elandri
http://landroverhell.com/article/4193/
Post #331725 9th Jun 2015 8:48pm
Ahh, yes. The disco tow bar is completely different in design to the one on the ff. to be honest knowing how they work I can't see how either could fail if properly engaged.
The one on the disco is located in position by a 20mm pin (see the pic) which fits into a cast receiver which is part of the rear subframe of the car and if properly engaged can't fail there is a small actuator on the bar itself which fires the pin into place. If this gets knocked early it can feel like it's in place but isn't!
The one on the ff is held in position with a spring loaded pin and ball bearings so a completely different mechanism, again if properly located it can't just fall off! It is possible to partially disengage it when it is locked but you physically have to do that and it still won't come all the way out. Have towed full loaded 3500kg trailers and thousands of miles with a caravan on the back with no problems whatsoever.
I would put the failures on the disco bar down to user error. Would be interested if anyone has had similar on the l322? There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 9th Jun 2015 10:31pm. Edited 1 time in total
Post #331735 9th Jun 2015 9:07pm
Zirconblue
Do none of these people use the break away cable? Or do they just loop it around the tow ball.....
I would expect the Disco one is the same as the Range Rover Sport, so i suspect that's where the rumour about "Range Rover tow bars" dropping off is from.
I expect those that have failed are down to abuse, poor maintenance or just plain user error. The same reasons trailers sometimes jump off of tow balls on various cars. It doesn't mean the tow ball is fundamentally flawed.
The quick release one is still ugly. The quick release is probably more secure in terms of theft prevention, as it locks onto the car. Whereas the farmers one with the pin needs a lump of chain and a padlock to stop someone just pulling up with another range rover and taking the complete hitch and trailer with them....
Post #331747 9th Jun 2015 10:09pm
