Home > Maintenance & Mods (L322) > Dash cup holder won't come out fix....
My passenger in dash cup holder has been getting harder and harder to get out and last week stayed stuck in... as they are rather expensive I thought I'd have a look... Dead easy to get out and sort...
Remove the dash end panel...
Undo the 8mm bolt at the back of the cup holder...
The push it out of the dash from the back... It has a toothed wheel on the top of it that damps it when it comes out, it seems that this becomes stiff over the years and causes enough friction to stop the spring pushing it out, this is the wheel
And this is where it lives...
It is held in with the two clips you can see on it's side at 1 and 7 o'clock in the picture, these locate in the two slots arrowed in the next picture, use a small screwdriver and you can pop it out. The cupholder will now be supercharged and fly out... It will still latch closed and work fine in all other ways...
Replace is a reversal of removing, this is not a fix to original spec, it comes out of the dash faster than before but at least it comes out and can be used again...
I tried to lube the wheel but nothing made a difference to it's friction...
SWMBO is happy now Thumbs Up :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #329810 28th May 2015 4:53pm
docjones
Finland
Isn't the gear the only thing preventing the cup holder tray from popping out? And when it does, you can not get it back in without removing the whole thing. The spring needs to be pushed back in from the back of it comes out.
DJ
Post #330691 3rd Jun 2015 12:07am
Zirconblue
I think there is also a latch, as you have to push it to release it.
The gear it just a damper to stop it shooting out like a rocket, and make it feel higher quality.
The glove box has the same sort of thing on it, until i replaced mine last week it used to drop like a stone when ever you pushed the release.
Post #330695 3rd Jun 2015 12:24am
It works fine if you let it out slowlyish after you push it in, it does stop when it's supposed to as Zirconblue said there are a couple of clips stopping it coming out on it's own... if you press it in and drop your finger off the bottom of it you may end up with it implanted in your head..... Rolling with laughter
As I said, this isn't a fix to original condition, but it does work and is a free fix if you don't want to spend £100 on a new one... I took the spring out of the center console one so you pull it out manually, mine worked but shot out on it's own when off roading, any small bump and out it came... at least it stays put now, you can pull it out by hand and it locks into position... Pete
Post #330753 3rd Jun 2015 1:17pm
Zirconblue
The little gear is just on a spindle smeared with damping grease (thick sticky grease), the reason they stick with time is the grease get contaminated with fluff and dust.
What happens if you flush it out with a bit of brake cleaner? Do is loosen the gear up a bit?
Post #330754 3rd Jun 2015 1:35pm
I gave it a good squirt with brake and clutch cleaner and then tried to take it apart but it doesn't seem to want to know... nothing made it any easier, it felt tight and ruff, think the plastic has just died... may go and have another play with it.... I'll keep you posted.... Thumbs Up Pete
Post #330756 3rd Jun 2015 1:40pm
chex
Kenya
Nice. This should be in the wiki.
Post #330763 3rd Jun 2015 2:12pm
Got the little wheel taken apart, used a very small screwdriver to prise it apart, it is indeed full of very sticky grease and has a little fan on it to cause drag, it even has a small seal to keep the goo inside... It appears mine is just worn out as I cleaned it all out and put it back together and it is still stiff and notchy, I guess the plastic has worn...
Post #330778 3rd Jun 2015 3:35pm
ebajema
I wonder if you reduce the viscosity of the grease by injecting some light machine oil, whether it start going again. As you say it is very sticky (i.e. high viscosity ?) then it makes sense that the lighter components have evaporated over time. MY 2010 5.0 SC Galway green and sand interior!!
Post #330790 3rd Jun 2015 4:23pm
I did clean it all out and tried it with nothing and it was still tight and knotchy, pretty sure mine is just worn out... Big Cry Pete
Post #330804 3rd Jun 2015 4:54pm
Zirconblue
The glovebox damper looks the same, but has a different bracket attached. They're £12 ish from LR, might be possible to mod one to fit the cup holder?
Post #330851 3rd Jun 2015 8:10pm
Shocked Shocked £12.... do you think I'm made of money mate...... Rolling with laughter
My fix was free and it works fine.... Thumbs Up Thumbs Up Pete
Post #330861 3rd Jun 2015 8:29pm
johnboyairey
my spring broke. so I drilled a small hole in the dimple, and fitted a £3 black ball shaped cupboard knob to it, from B+Q
So, now my missus gets to pull out my knob every time I buy her a Costa coffee.
Post #330895 4th Jun 2015 12:12am
Rolling with laughter Bow down Thumbs Up Pete
Post #330898 4th Jun 2015 12:47am
Naki
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Has anyone found a good permanent fix for the dash mounted cup holder (my car is 2003 L322).
I can see loads of fixes for the centre one? 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
2003 L322 TD6 Vogue with Facelift conversion
2000 Discovery 2 TD5 ES. Daily
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #584609 20th Feb 2021 7:10pm
