![]() | Home > Technical (L322) > Front CV Gaiter |
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
The inner clip disappeared from mine. I replaced it with a metal clip from a well know online auction site with the help of the correct pliers. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
the 'proper' metal clips are pigs. Plastic cable ties normally last as long as the boot, but you can buy stainless steel cable ties, which are far superior to the metal clips. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
check it hasn't gone anywhere near your brakes, i needed up with new discs because of grease from either a split ball joint gaiter or when the CV boot went south. There is nothing that can't be fixed with a hammer😜😜
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 226 ![]() ![]() ![]() |
Stainless steel cable ties ordered. Appear yo have avoided brake contamination thankfully. On inspection this evening, I found the originally cable ties which had ended up inside the gaitor. Presumably, it became loose and when the gaitor came off, the cable tie worked itself inside. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
