Home > Technical (L322) > Front CV Gaiter
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Front CV Gaiter
The front n/s CV gaiter has detached from the hub end. I do not recall seeing any form of clip or strap and checked the other side: no strap or clip three either.
I have looked on the forum and the consensus appears to be to use a cable tie. Therefore, I propose to clear our what old grease I can from the inside of the gaiter and replace with new stuff before strapping the gaiter back down with a cable tie. There does not appear to be any damage to the gaiter. Last job will be to scrape all the black grease that has been splattered across the underside.
Any other thoughts/suggestions? 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #331629 9th Jun 2015 8:31am
SO3isme
The inner clip disappeared from mine. I replaced it with a metal clip from a well know online auction site with the help of the correct pliers.
Post #331675 9th Jun 2015 4:55pm
Zirconblue
the 'proper' metal clips are pigs. Plastic cable ties normally last as long as the boot, but you can buy stainless steel cable ties, which are far superior to the metal clips.
Post #331679 9th Jun 2015 5:15pm
check it hasn't gone anywhere near your brakes, i needed up with new discs because of grease from either a split ball joint gaiter or when the CV boot went south. There is nothing that can't be fixed with a hammer😜😜
Post #331689 9th Jun 2015 5:51pm
RRBlue
Stainless steel cable ties ordered. Appear yo have avoided brake contamination thankfully. On inspection this evening, I found the originally cable ties which had ended up inside the gaitor. Presumably, it became loose and when the gaitor came off, the cable tie worked itself inside. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #331716 9th Jun 2015 8:18pm
