![]() | Home > Technical (L322) > Spare Key -Battery Problem |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
My understanding is they're recharged when in the ignition. So the logical thing to try is to use it for a week or so to charge it up. If you're the only person that drives it then you can just alternate between the keys once in a while. |
cgarside Member Since: 25 Mar 2015 Location: Preston Posts: 21 ![]() ![]() ![]() |
Thanks for your reply Zirconblue.
One problem that used to happen with old Rover's is if the remote had a battery change or was pressed several times when out of range of the car. The solution was to press the unlock button about 5 times to get the rolling codes resynchronised. I wonder if it's the same on the RR? |
Just been out try the unlock button five times - sadly no joy.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
had this on the spare key of mine when I bought it ,took it to the local indy and he re sync'd it to the vehicle for me free of charge ,need to go back know as I want global opening |
Thanks, that's jogged my memory. I had to reprogramme a spare key fob on another car a year ago. I will make some calls tomorrow and see if I can get hold of the re-sync routine.
you cant do it yourself it needs to be plugged in |
Didn't get the resync procedure but did follow rangies47's advice and went to the dealer. All done under warranty and sure enough the key re- programmed ok. Both keys now work fine
