|  | Home > Technical (L322) > Spare Key -Battery Problem |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277      | My understanding is they're recharged when in the ignition. So the logical thing to try is to use it for a week or so to charge it up. If you're the only person that drives it then you can just alternate between the keys once in a while. | ||
|  8th Jun 2015 10:34pm |
| cgarside Member Since: 25 Mar 2015 Location: Preston Posts: 24      | Thanks for your reply Zirconblue.
|  9th Jun 2015 6:53pm |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277      | One problem that used to happen with old Rover's is if the remote had a battery change or was pressed several times when out of range of the car. The solution was to press the unlock button about 5 times to get the rolling codes resynchronised. I wonder if it's the same on the RR? | ||
|  9th Jun 2015 7:01pm |
| cgarside Member Since: 25 Mar 2015 Location: Preston Posts: 24      | Just been out try the unlock button five times - sadly no joy.
|  9th Jun 2015 7:16pm |
| rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296      | had this on the spare key of mine when I bought it ,took it to the local indy and he re sync'd it to the vehicle for me free of charge ,need to go back know as I want global opening   | ||
|  9th Jun 2015 7:35pm |
| cgarside Member Since: 25 Mar 2015 Location: Preston Posts: 24      | Thanks, that's jogged my memory. I had to reprogramme a spare key fob on another car a year ago. I will make some calls tomorrow and see if I can get hold of the re-sync routine.
|  9th Jun 2015 8:00pm |
| rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296      | you cant do it yourself it needs to be plugged in   | ||
|  9th Jun 2015 9:17pm |
| cgarside Member Since: 25 Mar 2015 Location: Preston Posts: 24      | Didn't get the resync procedure but did follow rangies47's advice and went to the dealer. All done under warranty and sure enough the key re- programmed ok. Both keys now work fine
|  18th Jun 2015 7:42pm |
|  19th Jun 2015 5:55am |
| Posting Rules
