![]() | Home > Technical (L322) > Gearbox problem |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1849 ![]() ![]() |
He is talking out of his |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
^^ What he said!
sauzee Member Since: 11 Jun 2015 Location: Edinburgh Posts: 8 ![]() ![]() |
Thanks for you reply my son has taken the turbo out to clean it and he is also going to do the intercooler i think that the mechanic expects my Daughter to pay for the repairs,he has priced getting the bell-housing skimmed to take out the scoring but my worry is it has already been skimmed he sent it away before would that not increase the pressure in the box.He told me has built hundreds of these boxes without any problems
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Can't see why he would have to get the housing skimmed, if the TC was loose and scored it then it shouldn't be an issue with one that is correctly working...
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Dont garages talk a load of bull just to get your money, there seems very few people to trust these days as everyone is out to make a quick buck. |
@ JPS, yes, very sad. I have to say I hear it in my industry too (telecommunications) chancers spouting what they feel sounds like plausible buzz-wordy tech jargon when the content is largely b******s
OK, injectors do not cause gearboxes to fail. Even if the EGR valve needed cleaned out that's no cause for a box pump to fail. He's talking rubbish.
If he rebuilt the box, and the pump failed (which we already know 100% cannot be caused by a faulty engine fuel injector) then surely all the guaranteed parts, i.e. the box & its internals( are covered. If he cannot do it right first time then how on earth is your daughter responsible for buying replacement consumables? Again, talking rubbish.
Good Lord, I've heard some codswallop in my time but this really is an impressive sounding load of crap. So the car smokes a bit, so what? Why would that destroy torque converters? Even is the engine was somewhat out of balance due to only running on 5 cylinders that would never destroy a TC. The headlight conversion is wiring only which is controlled by the lighting control module. this is attached to the canbus but doesn't broadcast faults out on to the CAN. The connection to the CAN is to allow other items to know the lights are on, control the automatic lights function etc. It does not talk to the gearbox ECU even though both are CAN connected. The box doesn't give a toss if it's night or day and nor does it have a different shift pattern for night & day. Without wanting to sound blunt, the blokes a frigging idiot, and someone who clearly has difficulty in doing the job properly. The best advice would be to take it to some place more reputable and get your money back from him, preferably before he does more damage. Pete (Haylands) above makes a good point as do several others. Hopefully RRPhil will come along and add a proper specialist's view shortly. Good luck. |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
I would be looking to recoup my outlay to him via the small claims court. Provision of goods and services act 1979, and have it fixed properly. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
Talk about grasping at straws!
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
My gearbox went last year I was advisedvto take it to Mackie in glasgow Auto specialists . First class job with 3year warranty . Not cheap but good . No one in edinburgh recommended |
Thanks for all your replies,Swiftman this guy worked for Automotive Automatics in Leith for 8 years then started on his own about a year ago the only reason i took it there was because i had no way to take it to Glasgow as the car did not drive at all. She has already spent £2400 plus £250 getting the injectors done my son said he was down at Leith today so i think he was at his old work to see if they could help him i will hopefully find out tomorrow what he has to say
Hi I had mine taken through by recovery firm , mackies will collect car but I think it's about £150 for them to collect . When my box went I had to get gearbox , torque converter & transfer box all replaced . Plus mackie insist on a new oil cooler being fitted . |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
Agree with all of the above. Don't take any |
