![]() | Home > Maintenance & Mods (L322) > TD6 MY02- vibration when slowing to 50? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I could be being over sensitive, but have noticed recently that when slowing to 50mph and then driving at that speed, I start to feel an increase in vibration coming from the drive train. Also noticeable if getting up to 50 and pootling along in top gear @ 1800rpm.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Check those dreaded rear brakes for overheating/binding, as a starter for 10 |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
If it happens around 50 and speeding up or slowing down a little stops it, then i would start by getting the wheel balance checked. Even if the tyres aren't new, balance weights can fall off or pot holes can knock them out of balance a bit. |
There is no vibration or wobble on the steering... Will check rear brakes, though. Not changed wheels or dyes for ages! Away for a few days so may be a few days before I can report back. .
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Mine is similar as there is no wobble or vibration in the steering wheel. It is like a hum/resonance under the floor board/in the pedal that I can feel around 60 MPH and goes away once I hit 70 or drop below 55 2014 FF Autobiography 5.0 SC
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
I had this exact same issue and it was the TC, once it was replaced all noises gone. It's the lock up cloth that is disintegrating in the TC, between 50-70mph the lockup clutch starts to engage to lock the engine and gearbox together mechanically. When the clutch can't be engaged fully it makes like a vibration/drumming/cattle grid sound. For me it sounded like it was coming from the rear of the vehicle.
What's the TC? I only seem to notice mine though after I put in the 22s. Maybe I didn't pay attention with the stock 18s.
TC = torque converter
Someone explain the science? If correct tyres are used the rolling circumference is the same. How does this affect the gear ratios? I have been running on factory fitted 18" wheels for the last two years, prior to that 20" with correct tyres. I do think it may be the TC though |
There is loads of cases and info about this issue on the site and on the Internet in general. This is a site I found for a quick search talking about the vibrations caused by larger wheels.
^^ oh man....Not looking forward to that kind of pricey repair. Will it (TC) eventually fail if I keep the 22s on? I plan to go back to the 18s for winter. 2014 FF Autobiography 5.0 SC
Once the TC lockup clutch has started to fail you can't really stop it, the only thing u can do is replace the unit when the vibrations get bad.
So the TC is only "engaged" at the the 50-70 MPH range?
the lock up clutch only starts to apply at around 50mph and above.
