Home > Maintenance & Mods (L322) > TD6 MY02- vibration when slowing to 50?
I could be being over sensitive, but have noticed recently that when slowing to 50mph and then driving at that speed, I start to feel an increase in vibration coming from the drive train. Also noticeable if getting up to 50 and pootling along in top gear @ 1800rpm.
Just old age, just my old age Shocked , or the start of something? recon box fitted 80k ago, tranny oil changed twice since then. Thinking might be something to do with the torque converter ? .
Post #332554 15th Jun 2015 9:17am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Did you fit new wheels/tires?
Mine does this around 50 through 60 then stops at 70. Started happening after I put on the 22s and new tires I put on. I'm thinking its more to do with the tires. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #332607 15th Jun 2015 2:44pm
Check those dreaded rear brakes for overheating/binding, as a starter for 10 Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #332656 15th Jun 2015 8:35pm
Zirconblue
If it happens around 50 and speeding up or slowing down a little stops it, then i would start by getting the wheel balance checked. Even if the tyres aren't new, balance weights can fall off or pot holes can knock them out of balance a bit.
Post #332691 15th Jun 2015 11:42pm
There is no vibration or wobble on the steering... Will check rear brakes, though. Not changed wheels or dyes for ages! Away for a few days so may be a few days before I can report back. .
Post #332803 16th Jun 2015 8:51pm
horse86
Mine is similar as there is no wobble or vibration in the steering wheel. It is like a hum/resonance under the floor board/in the pedal that I can feel around 60 MPH and goes away once I hit 70 or drop below 55 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #332805 16th Jun 2015 8:57pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I had this exact same issue and it was the TC, once it was replaced all noises gone. It's the lock up cloth that is disintegrating in the TC, between 50-70mph the lockup clutch starts to engage to lock the engine and gearbox together mechanically. When the clutch can't be engaged fully it makes like a vibration/drumming/cattle grid sound. For me it sounded like it was coming from the rear of the vehicle.
Hope this helps
Matt
Post #332843 16th Jun 2015 10:59pm
horse86
What's the TC? I only seem to notice mine though after I put in the 22s. Maybe I didn't pay attention with the stock 18s.
How expensive was the fix? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #332857 17th Jun 2015 2:59am
mattstevenson2005
TC = torque converter
The L322 especially the 3L TD6 was never designed or intended to have anything bigger than 19" wheels the 4.4 V8 petrol was the only model at the time to have 20" wheels. Butting bigger wheels on will adversely effect the gear ratios.
Matt
Post #332873 17th Jun 2015 8:42am
Someone explain the science? If correct tyres are used the rolling circumference is the same. How does this affect the gear ratios? I have been running on factory fitted 18" wheels for the last two years, prior to that 20" with correct tyres. I do think it may be the TC though Smile .
Post #332881 17th Jun 2015 9:36am
mattstevenson2005
There is loads of cases and info about this issue on the site and on the Internet in general. This is a site I found for a quick search talking about the vibrations caused by larger wheels.
http://forums.lr4x4.com/index.php?showtopic=15803
In answer to your previous question my TC replacement and a gearbox refurbishment was about £1400 for my 4.4 petrol
Matt
Post #332894 17th Jun 2015 11:12am
horse86
^^ oh man....Not looking forward to that kind of pricey repair. Will it (TC) eventually fail if I keep the 22s on? I plan to go back to the 18s for winter. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #332923 17th Jun 2015 2:07pm
mattstevenson2005
Once the TC lockup clutch has started to fail you can't really stop it, the only thing u can do is replace the unit when the vibrations get bad.
Matt
Post #332928 17th Jun 2015 2:13pm
horse86
So the TC is only "engaged" at the the 50-70 MPH range?
I guess the good thing is I don't do much highway driving to/from work. There is only one stretch of road about 2 miles long where I get above 50 and generally take it to above 70 so the noise stops. On the rare occasions I'm on the highway I am above 70 anyway. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #332934 17th Jun 2015 2:29pm
mattstevenson2005
the lock up clutch only starts to apply at around 50mph and above.
if you do a search on this site you will find lots of threads on the topic as its a very common issue
Matt
Post #333000 17th Jun 2015 8:32pm
