Home > Technical (L322) > 4.4L TDV8 ZF 8HP70 flush : special technique?
TAKEN FROM RRPHIL’S POST ABOVE... I personally agree with the below statement and would NOT use a Britpart filter in my car!!! Rolling Eyes
None of the recommendations mention filter changes.
I would strongly recommend that only a genuine Filtran sump pan/filter should be used as there are a number of cheap(er) pattern parts out there. I notice, for example, that Britpart offer a service kit with the correct fluid
but I have no idea whether the sump pan is a genuine Filtran one or not.
Post #332690 15th Jun 2015 11:39pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
do non OEM filters have reputation or is it just cuz its OEM that we feel it must be used?
Question 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #332728 16th Jun 2015 1:44pm
Non OEM are built to a price and "their" specification which could be anything!!! The filter paper could be toilet paper or cardboard and you won't know till it either doesn't work and you run the bearings, fails and blocks an oilway or any other type of failure occurs, or it just doesn't filter too well and you wear your engine out faster......
An OEM one is built to a specification and will do what it says on the tin..... Pete
Post #332768 16th Jun 2015 6:11pm
Exactly as Pate says above... Never worth the risk IMHO Thumbs Up
Post #332771 16th Jun 2015 6:19pm
ajac8
Holy thread resurrection batman!
Just looking at changing the fluid on the ZF8 speed. Thought I'd do a reccy beforehand to make sure its a DIY job..removing the under tray reveals the drain plug which looks easy but I'm unsure if i have located the fill plug correctly. I have the WSM but the diagram is a bit crap to be honest.
I have located a plug about 30mm above the drain plug position in the same corner area of the filter (rear right hand corner of the filter looking from the rear of the car). There is a blue label under the plug but i cant make out what it says. It uses a 5 hex. Can anyone confirm that this is indeed the fill plug. It does not look high enough to me to get lots of new oil in but then again it looks like it could be.
The WSM calls for a special tool but it looks like it could be done with a hex nut and spanner to be honest. Question
cheers 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #424126 21st Jan 2017 6:24pm
proser
LR service schedule state replace oil and filter every 9years/144,000 miles Shocked Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #424143 21st Jan 2017 8:33pm
ajac8
Who on earth would leave that complicated bit f kit with the same lube for 144K. Madness. Takes no account of climate, drive style, towing, etc etc. It does not look a hard job to change the oil either. At the MD the cost of the oil is probably twice the labour! Shocked 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #424149 21st Jan 2017 9:04pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
A competent indie can do the job. Had mine done by an indie a couple of months back.
The difference is noticeable. Gear changes are quicker and smoother I think.
Had it done at 30k, 55k and will repeat at 80k.
Against the overall running cost of the vehicle, I am not bothered about spending 300 pounds on a fluid change for gearbox and transfer box.
Diffs I did at the same time.
Post #424205 22nd Jan 2017 11:14am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hi guys, have flushed with this:
http://www.ebay.de/itm/20-1x20-Liter-MANNO...SwB09YPACl
and filter was this:
http://www.ebay.de/itm/222184318070?_trksi...EBIDX%3AIT
good prices...... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #424225 22nd Jan 2017 1:08pm
stu
just tripped over this thread while searching for gearbox stuff, I have just been quoted £854 for a double flush by a localish independent. That seems like a lot of money to me? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #440213 31st May 2017 12:21pm
nino_nino
stu, I did my last winter (120 K km) in ZF workshop in Vienna and it was 615 euros.
Post #440237 31st May 2017 4:47pm
