![]() | Home > Technical (L322) > 4.4L TDV8 ZF 8HP70 flush : special technique? |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671
do non OEM filters have reputation or is it just cuz its OEM that we feel it must be used?
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8746
Non OEM are built to a price and "their" specification which could be anything!!! The filter paper could be toilet paper or cardboard and you won't know till it either doesn't work and you run the bearings, fails and blocks an oilway or any other type of failure occurs, or it just doesn't filter too well and you wear your engine out faster......
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392
Exactly as Pate says above... Never worth the risk IMHO |
Holy thread resurrection batman!
| proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452
LR service schedule state replace oil and filter every 9years/144,000 miles |
Who on earth would leave that complicated bit f kit with the same lube for 144K. Madness. Takes no account of climate, drive style, towing, etc etc. It does not look a hard job to change the oil either. At the MD the cost of the oil is probably twice the labour! |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845
A competent indie can do the job. Had mine done by an indie a couple of months back.
| Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325
Hi guys, have flushed with this:
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927
just tripped over this thread while searching for gearbox stuff, I have just been quoted £854 for a double flush by a localish independent. That seems like a lot of money to me? Current: TDV8 (3.6) RRS HSE
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
stu, I did my last winter (120 K km) in ZF workshop in Vienna and it was 615 euros. |
