Home > In Car Electronics (L322) > Cigar Lighters
Page 1 of 3 123>
Weegie
Cigar Lighters
I would like to change the front and rear cigar lighters (not the accessory sockets) to ignition switched as they get used for ancillary equipment and it would be more convenient to have them isolated when the ignition is off.
I have looked at the circuit diagrams and it appears that both the cigar lighters and the ancillary sockets go to the same fuse in the rear fusebox (fuse 1 20amp?). An additional complication seems to be that the colour coding is the same for all four outlets. That could obviously be overcome by removing in turn.
I am not quite clear if there is a spare fuse which could be used and wonder if anyone has any pointers.
Thanks in advance. John
GAP iiD BT-Sold
Post #333297 19th Jun 2015 10:25am
this came up a while back john and i suggested running feed wires from an ignition live socket but i'm sure someone came up with a better idea of changing the permanent live socket to an ignition live but i cant remember how.. ... - .- -.
Post #333299 19th Jun 2015 10:35am
Weegie
Thanks, Stan. Thumbs Up Will see if anyone has an idea. John
GAP iiD BT-Sold
Post #333307 19th Jun 2015 11:18am
i think this is the thread but its ignition live to permanent live thats been talked about..maybe the opposite can be done..
http://www.fullfatrr.com/forum/topic30360....ition+live ... - .- -.
Post #333318 19th Jun 2015 12:04pm
Weegie
Nice one, Stan. Thumbs Up Had a look and the relay is not there and there is a bridge in situ. Will look to acquire a relay (R132) which should, hopefully, do the trick. Need to source one. John
GAP iiD BT-Sold
Post #333330 19th Jun 2015 12:44pm
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Hi Weegie,
I also want this for my 02 l322, and have been looking into it for a while. Yet haven't found a simple solution. Where did you found out about the relay (R132)?
Please let me now if you have more information, really want this modification bad.... Bow down 2002 L322 V8
Post #333347 19th Jun 2015 1:37pm
Weegie
Rear compartment fuse box bridge instead of missing relay arrowed:
[/URL]
Then page 18 of circuit diagrams.
http://www.fullfatrr.com/gallery/albums/us...001_UK.pdf
[/img] John
GAP iiD BT-Sold
Post #333393 19th Jun 2015 5:06pm
pietertje
Thanks... You seem to have a slightly different set-up than mine... No bridge nor a relay for me... yet still my sockets are all live despite the engine turned off... Confused You also have lots more of fuses....
Sorry photo is a bit hard to see... Dark outside... Will take better photo tomorrow... 2002 L322 V8
Post #333491 19th Jun 2015 11:21pm
Weegie
Not sure but if you look at page 167 onwards on the above link it may give you a clue. It could well be that it is connected elsewhere than the rear fuse box.
What I find a little strange, going on my understanding, is that you are getting power to the sockets without either a relay or a bridge? But I might have it all wrong.
Mine is a MY2005 with touch screen etc so that may account for the additional fuses. John
GAP iiD BT-Sold
Post #333508 20th Jun 2015 8:01am
pietertje
Yeah already looked at page 167 and onwards. But it's a bit abracadabra to me.
Strange indeed, you would say that they are powered without a bridge or relay. Can I just plugin another relay to test what it does, or would that be a bad idea? 2002 L322 V8
Post #333519 20th Jun 2015 8:29am
Weegie
I wouldn't like to comment on that. Confused John
GAP iiD BT-Sold
Post #333535 20th Jun 2015 9:30am
Cheet22
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Was just going to search for this very issue when i see it top of forum.
I too would like my in car sockets to be ignition switched but they all remain live. 2002 4.4 vogue.
pietertje, my fusebox looks like yours, but with one extra relay to the top left of the group. Its yellow.
Guess we have some digging about to do.....
Post #333539 20th Jun 2015 9:49am
Cheet22
Just looked at that link to wiring diagrams.
So, we have two cigar lighters and two aux sockets.
The front cigar (next to gear knob), rear cigar (facing rear seats) and the aux socket in cubby box are all fed 12v permanent via fuse 1 in rear box.
The boot/trunk aux socket is also permament live, fed from fuse 7.
This all lines up with my car, if i remove fuse 1 they all die bar the one in the trunk.
So, i guess we need to find a way to feed an igntion switch wire into back of fuse 1 rather than permanent? But not sure if its quite as easy as that given it also runs through fuse in front fuse box?
Post #333542 20th Jun 2015 10:00am
Ethanicus
England 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Could you wire an inline voltage sensitive relay to kill the feed when the engine is off. 2010 - Range Rover VSE 3.6 TDV8
2014 - Defender 90 XS
2014 - Suzuki Swift Sport
2017 - GBS Zero
2006 - BMW Z4M Coupe (gone)
2004 - Discovery Landmark TD5 Auto (gone)
2008 - Defender 90 SX (gone)
2011 - Touareg Altitude (gone)
Post #333543 20th Jun 2015 10:03am
Cheet22
Accordng to page 17, a switched relay should control in car sockets.....
Post #333545 20th Jun 2015 10:11am
Page 1 of 3 123>
