Home > Maintenance & Mods (L322) > 2007 Front lip question
jamesbilluk
England 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi All
I was giving the car a car a good clean last night and when I came to the front I noticed that around the front towing eye, the plastic on the front lip is slightly pushed up, making the towing eye cover not fit properly, not sure how this happened, the rest of the front of the car looks fine though- here's a photo where it's just visible-
Is there a way this can be straightened? Or replaced easily?
Many thanks
James
Post #333364 19th Jun 2015 3:38pm
a close up picture would be beneficial... ... - .- -.
Post #333370 19th Jun 2015 3:51pm
jamesbilluk
Hi Stan,
Here are some close up images just taken-
Post #333376 19th Jun 2015 4:04pm
looks like the metal tow bit is to high..have you tried taking it off to see whats what.. ... - .- -.
Post #333378 19th Jun 2015 4:07pm
this is mine .. ... - .- -.
Post #333379 19th Jun 2015 4:10pm
jamesbilluk
Many thanks for the photo,
Certainly does look like mines too high, I'll pop down and have a look now,
James
Post #333381 19th Jun 2015 4:14pm
That happens with an over zealous recovery driver who has winched it on his truck, chocked the wheels and then tightened the winch again bending the tow point upwards...
If you have a big enough prybar you should be able to pass it through the top of the tow hook, brace it against the front crossbar and bend the tow hook down to where it should be... Pete
-Click here for Thread-
Post #333382 19th Jun 2015 4:16pm
jamesbilluk
Many thanks,
Just been to have a look, certainly does look like that's when happened, seems much higher than it should be.
I've taken the cover off for now, seems to look neater and more straight.
I shall have a look in the garage, see if I have one, if not I'll pop down to the local garage, see if they have one,
Many thanks again
James
Post #333387 19th Jun 2015 4:28pm
