![]() | Home > Technical (L322) > Air Suspension problems on MY2011 FFRR bought last week! |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
Presumably you've got a 3 month warranty on the vehicle - don't all dealers have to do this now ??
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Sounds like the compressor. The fact the car stays the same height overnight suggests the airbags are fine.
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
I agree with Ian. It sounds like compressor. I had this along with forward alert not available. Had the compressor replaced and everything is ok now. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
Can i suggest starting the car from cold, leave it running for ten minutes (without touching the suspension settings) then press off road height and report back with your findings... |
Silverwebfox Member Since: 08 Jun 2015 Location: England Posts: 11 ![]() ![]() |
Apologies for the delay in coming back. Tried the ten minutes as suggested, still would not go to offroad height. Took the car to an independent garage for a full report. It has confirmed that the compressor needs replacing.
Where in the country are you sir? |
Mid - Sussex, just north of Brighton. Why may I ask? |
As we are (hopefully) a trusted site sponsor/independant FF specialist sir... But based too far away from you sir |
Ah yes, I'd already thought of you but as you say too far away.
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
There is a cheap fix for this ,it is just the piston ring in the compressor I fixed mine for £20.Google it on ebay 'l322 air compressor piston ring' then look up same fix on 'you tube' where there is a 10 min video to show you how to fix it.You may however have to get it 'reset' with a plug in when you have finished ,see the other forum subject on this 'technical' page!! |
Waddy Member Since: 02 Jan 2017 Location: Huntingdon Posts: 2 ![]() ![]() ![]() |
Hi there, sorry to raise an old thread but was wondering if this issue was resolved and if so, what the remedy was.
Not sure if your symptoms are similar but if you read this waddy/ might be of some usec |
Seems the same symptoms as above and with mine. Potentially a new compressor unit needed by the sounds of things. Was this the cure for Silverwebfox? |
