![]() | Home > Technical (L322) > Air suspension inactive - air spring |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 ![]() ![]() ![]() |
Hello,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8790 ![]() ![]() ![]() |
Do you have any lights on the suspension panel in the center console???? or are they all out... Pete
After I got the message on the dashboard saying Air suspension inactive, the lights get off! I can't change suspension position. Ex-FULLFATTY now downgraded
Your a bit stuck then, it needs a hard reset with a diagnostic tool, it may then come back up and be OKish at standard height, sounds like the hole is under the fold so sealed when at standard height...
Do you have to stand on one leg and face east as well.......
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
interesting ![]() |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
I think you'll find that relates only to the OBC info system and not any other ECU's.
Thanks Weejock and others!
Not too bad then, at least you got it sorted... Pete
Good news then!
Thanks Weejock, that information was precious. I will replace the other when I arrive home!
