![]() | Home > Duckworth Parts > Bonnet Closed Switch |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383 ![]() ![]() |
Dan,
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
Hi
Thanks Dan, I'm doing some investigations before I order a new part, will reference above if/when I do.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962 ![]() ![]() ![]() |
If it helps I took mine of cleaned it with switch cleaner and replaced, sticking a small rubber foot from a computer under the bonnet where it touches. Obviously pushes the plunger home a bit further - no trouble since (alarm kept going off). Geoff |
Might try that in short term to see if it helps, thanks. Discovery 4 HSE
I got that picture from the RAVE system and mine does NOT have the white cap, it is like yours.
Van Diesel Member Since: 27 Oct 2013 Location: Norfolk Posts: 183 ![]() ![]() ![]() |
Cheers @ RRUK - Got a rag in between the bonnet and switch holding down at mo. Will prob disconnect ! |
As we'd only had the car less than a week decided to give the dealer a ring for them to have a look. Turned out to be a very slight mis alignment with the bonnet which meant the switch was not being fully depressed when closed?
