Home > Duckworth Parts > Bonnet Closed Switch
Dan,
How much for the push switch that sits on the drivers side under the bonnet to tell the car if the bonnet is open or not? I need the plunger part, not the wiring or connector
Thanks
 Discovery 4 HSE
Post #324776 28th Apr 2015 12:18pm
duckworthparts
Site Sponsor
Hi
YUE000162 £14.000inc vat posted You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #324931 29th Apr 2015 12:52pm
Thanks Dan, I'm doing some investigations before I order a new part, will reference above if/when I do.
Adam Discovery 4 HSE
Post #324933 29th Apr 2015 12:53pm
duckworthparts
Site Sponsor
Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Post #324936 29th Apr 2015 1:12pm
supershuttle
If it helps I took mine of cleaned it with switch cleaner and replaced, sticking a small rubber foot from a computer under the bonnet where it touches. Obviously pushes the plunger home a bit further - no trouble since (alarm kept going off). Geoff
Post #324966 29th Apr 2015 3:34pm
Might try that in short term to see if it helps, thanks. Discovery 4 HSE
Post #324973 29th Apr 2015 3:42pm
Van Diesel
United Kingdom 2014 Range Rover Vogue SE SDV8 Mariana Black
Got a warning coming up saying bonnet is open (which its not). Just noticed at the top of this thread that the photo looks different to my switch? Can somebody confirm if I'm missing a white cap?
Pain in the Censored as can't lock it while this is showing up.
Post #334386 25th Jun 2015 2:47pm
I got that picture from the RAVE system and mine does NOT have the white cap, it is like yours.
I disconnected mine, so no more alarms going off when it heats up on the driveway! Discovery 4 HSE
Post #334390 25th Jun 2015 2:50pm
Van Diesel
Cheers @ RRUK - Got a rag in between the bonnet and switch holding down at mo. Will prob disconnect !
Post #334398 25th Jun 2015 3:45pm
Van Diesel
As we'd only had the car less than a week decided to give the dealer a ring for them to have a look. Turned out to be a very slight mis alignment with the bonnet which meant the switch was not being fully depressed when closed?
All sorted now anyhow !!
Post #334933 28th Jun 2015 8:41pm
