Home > Maintenance & Mods (L322) > BMW transmission kit equivalent for 2004 RR
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Hi all, first post on this RR forum. I can get BMW parts at employee cost. Anyone know what model and year BMW transmission filter/gasket/fill plug kit to order? I want to assume from a 2002/3 X5.
Also need the O rings and any gaskets for my leaking oil filter housing.
In general would like to know all and BMW parts that in the 2004. Thanks.
Post #334434 25th Jun 2015 7:10pm
Zirconblue
I don't know off hand, but when i did mine, i noticed the part number for the oil is printed on the bottom of the gearbox.
The Filter is the same one as the Early X5, E53 i think the internal model number is.
Pretty much everything on it is from the X5.
Post #334447 25th Jun 2015 8:04pm
doclees
Thanks I'll give it a try. I read somewhere that the 5hp24 in the BMW had a different case than the RR(FF) so I wasn't sure if the pan shape could be different.
Post #334480 26th Jun 2015 12:52am
Zirconblue
The Pan on the bottom is the same it has BMW written all over it.
Post #334563 26th Jun 2015 4:45pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
The 5HP24 is unique to the L322 and does have a different case however it shares most parts with other versions, the main difference is the output shaft as the L322 has a 2 speed transfer box whereas other BMW/Jaguar versions don't.
The sump pan and plugs are the common across all models of 5HP24 as confirmed in the ZF parts manual:
http://www.zf.com/media/media/document/int.../5HP24.pdf
I use Realoem for BMW part number equivalents.
http://www.realoem.com/
E53 X5 4.4i M62 from early 2003 will be the same for common parts.
e.g.:
http://www.realoem.com/bmw/enUS/partgrp?id...&mg=24
Post #334593 26th Jun 2015 7:18pm
doclees
Thanks. I use RealOEM too for part numbers. My daughter works for a Mega car dealer. I was surprised that even with her discount the kit was still $100 US and $15/liter for fluid. Are the BCM and PCM swapable?
I was also hoping for a miracle and that BMW could provide a VIN coded key. Anyone know if it is possible?
Post #334742 27th Jun 2015 6:21pm
