![]() | Home > Maintenance & Mods (L322) > BMW transmission kit equivalent for 2004 RR |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Hi all, first post on this RR forum. I can get BMW parts at employee cost. Anyone know what model and year BMW transmission filter/gasket/fill plug kit to order? I want to assume from a 2002/3 X5.
Thanks I'll give it a try. I read somewhere that the 5hp24 in the BMW had a different case than the RR(FF) so I wasn't sure if the pan shape could be different. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
The Pan on the bottom is the same it has BMW written all over it. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
The 5HP24 is unique to the L322 and does have a different case however it shares most parts with other versions, the main difference is the output shaft as the L322 has a 2 speed transfer box whereas other BMW/Jaguar versions don't.
Thanks. I use RealOEM too for part numbers. My daughter works for a Mega car dealer. I was surprised that even with her discount the kit was still $100 US and $15/liter for fluid. Are the BCM and PCM swapable?
