![]() | Home > General > Should I pull the trigger? |
Robbo1982 Member Since: 03 Mar 2015 Location: South East Posts: 9 ![]() ![]() |
Hi All,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8740 ![]() ![]() ![]() |
Looks nice, clean and straight but photos can be deceiving...
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2715 ![]() ![]() ![]() |
As above really, but lovely colour, good luck! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7977 ![]() ![]() ![]() |
Will need a service in a few weeks as last done Aug 2014. Nice bargaining tool. Looks tidy though. I don't dislike Tonga green.....
Hammer on weights are the wheel balancing weights you can see on the wheel, they have a steel fixing and a zinc weight, the steel and alloy wheel set up electrolysis and can rot out a hole in the wheel, they also damage the paint on removal...
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
looks a tidy car and not expensive either, id buy it if it looks as good in the flesh |
Cheers Pete. Will follow your advice for sure! |
Can I suggest you read every word of this link before you go to look at it, you really need to know how it works and what it should have...
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Looks really good and not a great deal of money either.
Make sure steering wheel goes up and down and in and out. Can be expensive to fix.
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Nice looking car.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
looks like a nice one. But its difficult to tell from pics.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1422 ![]() ![]() ![]() |
Have a look at the area to the rear of the engine, ideally from underneath as well as from above, for blue/green residues of coolant which can be blown out due to cylinder head problems. That was what did for my 2004 car's engine, even though it sounded and ran fine. Only Range Rovers since 1988 |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
What year is the car ? - if it has "6A" in the VIN, it's an '06 model year. Definitely the petrol engine to go for as it is the Jaguar (not BMW) 4.4 V8 with 6 speed ZF gearbox. The post above does not refer to this engine which is very highly regarded.
