Home > General > Should I pull the trigger?
Robbo1982
Hi All,
Am shopping for a Range (hence lurking here... a lot!) have more or less decided that an 05 model is probably the way to go given my funds at this time and it being my first time owning one of these cars...
have put a refundable deposit on the attached... hopefully going to view sat/ sun
http://www.asmperformance.co.uk/used/land-...e/16202124
Just wanted to get peoples thoughts really? Looks like a fair price. Seems to have history guy said good condition but some stone chips to front bumper, 3 owners MOT due May next year, no advisories.
Will take the wiki list with me when i go and view. Does this look like a fair price?
Cheers
Robbo
Post #334573 26th Jun 2015 6:57pm
Looks nice, clean and straight but photos can be deceiving...
Only negative I can see is the hammer on wheel weights, tend to damage the alloys and are totally unnecessary these days... And condensation inside the off side rear light... very difficult to sort, really needs a new light...
Make sure you open the rear doors and look for rust around the wheel arch and down towards the sill covers and both upper and lower tailgates...
Then press every button and make sure it works.... incl low box and HDC....
Good luck, don't let your heart rule your head, there are plenty out there for sale..... Pete
-Click here for Thread-
Post #334576 26th Jun 2015 7:20pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
As above really, but lovely colour, good luck!
Post #334579 26th Jun 2015 7:27pm
mjdronfield
Will need a service in a few weeks as last done Aug 2014. Nice bargaining tool. Looks tidy though. I don't dislike Tonga green.....
Good luck on your viewing. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #334585 26th Jun 2015 7:41pm
Robbo1982
thanks guys! Hadnt even noticed that condensation!!! Doh..
Quick one Pete, what is the low box?! and what does hammer on wheel weights mean? (i have been staring at the wheel image for 20 mins now!!!)
great having such brainy people on the forum...! Virtual beers or real ones if i am ever passing through or there is a get together!
Post #334600 26th Jun 2015 8:42pm
Hammer on weights are the wheel balancing weights you can see on the wheel, they have a steel fixing and a zinc weight, the steel and alloy wheel set up electrolysis and can rot out a hole in the wheel, they also damage the paint on removal...
The Range Rover has a 2 speed transfer box, low range is for offroading, if it's not used regularly then it can get upset and refuse to work, this can cause other problems and cost a lot of money to fix, even if you don't want to use the low box you should put it in and out every few weeks to keep things working well.... Pete
Post #334605 26th Jun 2015 8:48pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
looks a tidy car and not expensive either, id buy it if it looks as good in the flesh Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #334606 26th Jun 2015 8:49pm
Robbo1982
Cheers Pete. Will follow your advice for sure!
Post #334607 26th Jun 2015 8:55pm
Can I suggest you read every word of this link before you go to look at it, you really need to know how it works and what it should have...
https://topix.landrover.jlrext.com/topix/c...oupId=1655 Pete
Post #334609 26th Jun 2015 8:59pm
Looks really good and not a great deal of money either.
As said, make sure everything works. Put the suspension up and down a few times and check the bags for signs of cracking when fully extended. It would be worth checking if they have indeed been changed at any point.
Thumbs Up Previously..
Post #334611 26th Jun 2015 9:03pm
mjdronfield
Make sure steering wheel goes up and down and in and out. Can be expensive to fix.
The TV prob won't work as I think it's still an analogue tuner. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #334618 26th Jun 2015 10:01pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Nice looking car.
Think the condensation may be the reflection of merc headlight parked near it.
As Pete said check the topix & good luck with the search. Thumbs Up
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #334620 26th Jun 2015 10:20pm
looks like a nice one. But its difficult to tell from pics.
There appears to be a crack in the heated seat button, check it will work OK. there is a buying guide in the wiki with loads of things to check out. There is nothing that can't be fixed with a hammer😜😜
Post #334628 26th Jun 2015 10:56pm
CS
Have a look at the area to the rear of the engine, ideally from underneath as well as from above, for blue/green residues of coolant which can be blown out due to cylinder head problems. That was what did for my 2004 car's engine, even though it sounded and ran fine. Only Range Rovers since 1988
Post #334648 27th Jun 2015 9:51am
TugRR
What year is the car ? - if it has "6A" in the VIN, it's an '06 model year. Definitely the petrol engine to go for as it is the Jaguar (not BMW) 4.4 V8 with 6 speed ZF gearbox. The post above does not refer to this engine which is very highly regarded.
I owned one for 18mths with the only not maintenance issues being a replacement radiator & MAF sensor. Surprisingly good on fuel with proper performance, too.
Yes, read the buyer's guide but don't get too hung up on it as if you went through all the detail and you're of sound mind you wouldn't buy one anyway !
Looks like a well priced car to me - if it has been properly maintained, it should be excellent -
Thumbs Up Where do you go after one of these . . . ?
Post #334649 27th Jun 2015 10:03am
