Home > Maintenance & Mods (L322) > New owner some problems with new buy
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
Hi guys new rr owner here
It's a vogue 54 plate but it has the 2010 facelift on it.
Can anyone help with the below.
Drivers side wing mirror won't adjust at all, also when pressing the fold button just clicks and doesn't move. The passenger side is fine for all functions.
The push out cup holder in centre console is very tempremental, pops open when the lid on the console is shut so guess it's really worn, are they easy to change out for a new unit?
The key fob is very worm out, it's the old style non flip, if I buy a new case for it off eBay can I also swap blades or just the PCb and then get new blade cut?
This forum looks great I'll post some pics up when I'm on the desktop rather than iPad, thanks Scott
Post #334732 27th Jun 2015 6:19pm
Nicka2311
Scotland 2005 Range Rover Vogue Td6 Java Black
welcome to the forum.
There is a thread on here about the key, will try and find it.
Cupholder is easy to replace there is a section on the workshop manual found through the wiki section on how to do it.
As for the mirror it sounds like the connecting teeth that rotate the mirror out are broken '55 Java Black Vogue
Post #334734 27th Jun 2015 6:25pm
Ohwhatalad
thanks shall take a look at the wiki !!
Also whats the cheapest route to go down to replace interior parts with piano black ones?
ive seen kits on powerfull website but not only expensive, mainly out of stock!
In desperate need of the window switch surrounds as mine are horrible condition but will replace door handles and other parts too if i can find one place to order it all from?
Post #334739 27th Jun 2015 6:47pm
Try Clarks in Peterborough- they did my last car - took out the wood trim and painted it all gloss black and refitted
I had the car over 4 years and it still looked immaculate
Cost under £500 including removal and re-fitting Thumbs Up
http://www.clarkspremierbespoke.co.uk
Post #334761 27th Jun 2015 8:52pm
Ohwhatalad
Thanks for the tip was that just the wood trim or the silver trim door handles and gear change surround etc aswell mate?
Post #334763 27th Jun 2015 9:06pm
I had everything that was wood done piano black - not sure which silver bits you mean, but I think they can paint most things - give them a call and ask Thumbs Up
Post #334794 28th Jun 2015 8:12am
