![]() | Home > Wheels & Tyres > Tyre wear |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I'd recommend getting a proper 4 wheel computer alignment done. You can have a car that drives fine but with the caster, camber and toe geometry all over the place. It's not until it's set up properly you realise how bad it was.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
Cheers my friend.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Just sit in it whilst he does it. middle of back seat... Pete
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Best kits for the alignment is the hunter Hawkeye, make sure your chap can check the front and rear toe, camber, castor, steer ahead etc.
Cheers Gents |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
Isn't Tyre Wear a place in the North East?!! |
if you say it with a geordie accent it is... |
But they're still only as good as the bloke using them. The Hoffman and is it John Bean or something? are both capable of good results if used by someone who knows what they're doing. Used by numpty none of them will be much good. ![]() |
^v true.
The Hoffman one i had mine done on has that too. |
