Home > Wheels & Tyres > Tyre wear
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Tyre wear
The front and rear offsides are wearing their inner shoulders down as per the photo. Nearsides look fine.
Anyone hazard a guess as to why? Car drives fine and I'm always keen to keeping pressures correct.
Many thanks Thumbs Up
 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #335074 29th Jun 2015 4:48pm
Zirconblue
I'd recommend getting a proper 4 wheel computer alignment done. You can have a car that drives fine but with the caster, camber and toe geometry all over the place. It's not until it's set up properly you realise how bad it was.
if there are no obviously worn bushes or anything bent, then i would expect it's just an adjustment issue.
Post #335094 29th Jun 2015 5:48pm
ajac8
Cheers my friend.
I've spoken to my Indie who has all the kit for 4 wheel alignment. Has has also said I need to have a full tank of fuel - which will cost more that the wheel alignment. Big Cry 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #335125 29th Jun 2015 6:41pm
Just sit in it whilst he does it. middle of back seat... Pete
Post #335133 29th Jun 2015 6:53pm
Best kits for the alignment is the hunter Hawkeye, make sure your chap can check the front and rear toe, camber, castor, steer ahead etc.
the rear wear is possibly down to a worn top bush on the hub, the front is probaby down to toe being out (or in) Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #335177 29th Jun 2015 8:25pm
ajac8
Cheers Gents Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #335240 30th Jun 2015 8:09am
Roystonh
Isn't Tyre Wear a place in the North East?!! Laughing 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #335279 30th Jun 2015 3:00pm
if you say it with a geordie accent it is... Laughing ... - .- -.
Post #335285 30th Jun 2015 3:54pm
Zirconblue
But they're still only as good as the bloke using them. The Hoffman and is it John Bean or something? are both capable of good results if used by someone who knows what they're doing. Used by numpty none of them will be much good. Sad
Post #335294 30th Jun 2015 4:43pm
^v true.
One of the advantages of the hunter kit (and they have it at some kwikfits Rolling Eyes now) is that you can see from the screen what they are doing and get a printout to confirm everything is ok. There is nothing that can't be fixed with a hammer😜😜
Post #335296 30th Jun 2015 4:56pm
Zirconblue
The Hoffman one i had mine done on has that too.
Post #335300 30th Jun 2015 5:13pm
