![]() | Home > Technical (L322) > Parking sensors not doing anything. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
low voltage batterys do cause all kinds of weird things on the FF , from hdc problems to the nav screen not coming on...
Blade74 Member Since: 01 May 2015 Location: Sydney Posts: 55 ![]() ![]() |
I put the battery on charge for a few hours and it seemed to be fully charged.
do a proper drop test on the battery...how old is it? anything over 3'ish years could be suspect and i think there's a tsb on battery drain on your model year.. ... - .- -.
I'm not sure how old the battery is but its branded Land Rover/Jaguar 90ah.
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Hi Blade,
Thanks RJH,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
that looks like it has been replaced, afaik, the 2010 cars came with a standard Lead acid battery, which was upgraded to the AGM type following the TSB (technical service bulletin). Yours has the AGM type so i would suggest that it has been replaced. There is nothing that can't be fixed with a hammer😜😜
With the engine running there should be enough charge to have full voltage on the system i.e. the parking sensors should work. The NRMA check should have shown bad charging issues so lets assume for now it is charging properly.
It looks like the battery was replaced with recall q159 04/12/12 with battery management system.
Glad that you found it, crappy design though |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
wold be interested to know if it was the module. let us know if a replacement fixes the issue. |
Great that it was of help in finding that, could well be condensation Its worth keeping an eye on it to be 100% tho.
Thanks RJH.
