Home > Maintenance & Mods (L322) > Rear Disc Replacment
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
I have some new rear discs and parking brake shoes to fit.
The workshop manual says put Handbrake in mounting position. I have an IIDTool so can do this. But is it necessary as long as I use the correct embedding in procedure?
The manual doesn't say to 'unmount' the brake by the diagnostics after all is reassembled. And still stays to flick the adjuster all the way back so no idea what the mounting position adds to this. Maybe stops some inadvertent damage to cable....
Cheers
Post #336405 8th Jul 2015 7:45am
Zirconblue
Is it so you can get the discs off?
Like when removing the drums from an old drum brake, if the drum is worn you have to wind the adjusters right back to get the shoes to clear the lip worn on the edge of the drum.
Post #336441 8th Jul 2015 11:57am
As above, It's to get the parking brake shoes off the inside of the disk, to allow it to be removed. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #336442 8th Jul 2015 12:07pm
stenh02
Yes, I appreciate that. It was more for the point of view if the T4/IIDTool/Diagnostic service 'mount' procedure adds anything that the wee adjustor does not.
Maybe I'm confusing the issue.
I presume you can change the rear discs with out a diagnostic machine just by using the adjuster to ease the shoes off the drum.
Given I have an IIDtool that can 'mount' the brake - does this add anything more than the standard?
Does that make sense?
Post #336445 8th Jul 2015 1:03pm
I have an IIDTool and I didn't do anything with it when I replaced my rear disks.
The procedure I used was to wind the shoes in using the little cog that's behind a cover on the disk back (whilst counting the turns), then doing the reverse when the new disks were fitted.
I'm not really sure what the IIDTool procedure actually does in this context. Got - 2017 SDV8 Autobiography in Loire Blue
Post #336446 8th Jul 2015 1:13pm
stenh02
Thats fine, thanks.
I won't use it but it would be nice to know if it was anything useful.
Post #336447 8th Jul 2015 1:18pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi Guys
-Mounting position is to allow removal / installation of the disks without playing with the cog wheel.
-Latching is normal operating position (ready to engage)
Cheers http://www.gap-diagnostic.com/
Post #336477 8th Jul 2015 5:24pm
stenh02
Thanks Patrick. Thumbs Up
Post #336484 8th Jul 2015 5:50pm
