![]() | Home > Technical (L322) > Smoke from under the bonnet |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
difficult to diagnose something like this...could it have been water on the exhaust or a shredded belt? ... - .- -.
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
Could it have been the FBH letting off steam... (thinking about it I talked myself out of that cos they are temp related and I doubt it would have cold enough to trigger)
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
It is possible it's something not serious, like a carrier bag stuck to the exhaust. - if you feel able, you could look with a good torch, underneath in off-road height, just peering under on your side. And when completely cold, maybe feel around the manifolds, for melted remains etc.....
| kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335
My ac compressor clutch have off a fair amount of smoke when it went a few weeks back. But as said it could have been almost anything so best to take a look and use your nose to try to smell burnt electrics / plastic etc. |
Is it not the depths of winter down under this time of the year? Does anyone know what temp it is? As would rule out FBH |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Could be the fbh, wasn't that warm in Sydney today.... Certainly cold enough for it to run. There is nothing that can't be fixed with a hammer😜😜
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215
As tractor engines are notoriously smokey nearly all the time its most likely that the wind was blowing the wrong way. |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
Well he said he filled up with desiesel so I'd go with the Fuel burning heater , it's certainly cold enough right now even here .
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
FBH |
i thought FBH, but OP says it didnt smell like diesel ? ... - .- -.
| Blade74 Member Since: 30 Apr 2015 Location: Sydney Posts: 55
I started it this morning and no smoke.
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804
More than likely it was the FBH. When the FBH runs, the smell is more like burning 'paraffin' rather than the diesel exhaust smell you get from running the engine.
I think you're right Discotigger and as others have said.
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
FBH has three functions really.
| All times are GMT |
