Home > Maintenance & Mods (L322) > Service items that aren't changed on every service
dhallworth
Our SC has only ever been serviced by main dealers and has been done every 12 months regardless of mileage when looking back through the receipts and service book.
Just recently I've noticed that the economy has dropped (not that I really watch it but I've noticed it's needed filling more often).
Today on a run I decided to sit at 56mph with the cruise on and it was only averaging 25.1mpg (reset the trip after putting the cruise on), I know it can do more then that as I've measured it once before when sitting in average cameras at 60.
After a run of around 20 miles I got out and felt all the wheels, mainly the rears in case the calipers were dragging, all the wheels were stone cold. I checked the tyre pressures, they were all spot on as well.
Once I got home I decided to whip the air filter out and have a look and it was pretty disgusting. The car was only serviced 2k miles ago by the main dealer but I've noticed that the air filter doesn't get replaced at every service when following LR service schedules.
I'm going to order one from Dan tomorrow, but was wondering if there's anything else that's worth changing at the same time that isn't done on every service such as spark plugs, fuel filters etc?
My last service receipt shows oil filter, pollen filters and oil and judging by the fact the oil is still golden I'm fairly confident the work was done and they've not just taken the p!ss.
Any thoughts and opinions would be appreciated Smile
Post #337116 12th Jul 2015 9:53pm
i've also wondered if the spark plugs need changing and if so would they make the SC run better.. ... - .- -.
Post #337122 12th Jul 2015 10:06pm
dhallworth
It'll be interesting to see what the general consensus is Smile
I've just looked on Rimmer Bros. website, for "Genuine LR" spark plugs they want nearly a tenner a plug Shocked
Post #337124 12th Jul 2015 10:08pm
not cheap are they...
i remember changing the plugs was the regular 'thing' to do on the old cortina's and mini's..... ... - .- -.
Post #337125 12th Jul 2015 10:10pm
dhallworth
On all of the P38's I've had I've given them all a big service just as I've got them (all filters, plugs, and all the fluids). At least on the P38's you can change the plugs in 10 minutes as they're easy to get to. With a Halfords trade card plugs for the P38 worked out at about a quid a plug too!
Post #337128 12th Jul 2015 10:18pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I commented on this exact same thing a while back, we've had ours serviced regularly by a main dealer, but the last service our local guy did it, and guess what, air filter filthy and the spark plugs had not been changed for a long time. One of the comments on my thread was that these days plugs are only changed every 100,000 miles!
Anyway, main dealers will only see it now if it's something that our local guy can't do!
Post #337131 12th Jul 2015 10:19pm
Zirconblue
David.
Rimmer's aren't known for their cheap prices, mostly they just sell them at the main dealer retail price! Except most dealers will discount if you buy from them on a regular basis. But try looking up the price for plugs on a BMW 4.4 engine. £240! for a set of 8!!!! They're only made by Bosch, NGK etc for BMW/LR and you can get them for about a third of that from a factors!
Post #337136 12th Jul 2015 10:48pm
dhallworth
The plugs for the 4.2 SC are NGK IFR5N10.
Looking on eBay, around about a tenner a plug doesn't seem that far off the mark!
Will see what Dan can sort in the morning Smile
Post #337138 12th Jul 2015 10:52pm
dhallworth
Have just read this on the all about automotive
Quote:
Vehicle manufacturers make much of the fact that their products come equipped with extended-life spark plugs that can maintain a precise gap for 100,000 miles. However, before you wait that long to replace them, you should bear in mind that spark plugs that hit the 80,000-mile marker are four-fifths worn. As the gap in the plug widens, engine performance and gas mileage begin to suffer. In addition, spark plugs that have remained in place for tens of thousands of miles have a tendency to seize in the cylinder head or the two piece designs tend to break. Once this happens, it can be potentially costly job to remove them. Since your vehicle’s spark plugs are going to require replacement sometime, better to do it sooner rather than later.
Makes sense to change them I guess.
Post #337140 12th Jul 2015 10:56pm
Zirconblue
The electrodes might well last, but often the ceramic insulators start to crack.
It's a lot like cam belts. the manufacturers run lots of engines on a test bench, and see how long it takes before the cam belt snaps. Then they pick a figure somewhere below the average as a service interval. It does no harm to change them before they get to that.
Post #337155 13th Jul 2015 1:27am
David, as a general rule of thumb on my own car... If JLR say it needs changing at 10k or 100k i will change it at 5k or 50k! I do VERY low miles! I personally believe time can do as much damage as miles on certain components hence the rule of thumb Thumbs Up
We adopt a similar approach when it comes to servicing customers cars too. Things like air & fuel filters are left for way too long if following JLR schedules on some models IMHO... I believe the small amount more we charge at point of service will not only return you reliability & good/better longterm wear but will more than pay you back ten fold in fuel savings between servicing...
But then i guess thats why good indie’s are worth finding, as we get to think outside the JLR box, use common sense & save customers money Whistle Whistle Whistle Thumbs Up
Post #337159 13th Jul 2015 5:07am
dhallworth
Thanks Craig.
I've PM'd Dan for plugs, an air filter, front and rear diff, transfer box and gearbox oil and a filter as well. Might as well give her a good service whilst sorting her out.
Since Its service in December it's only covered 2k miles so won't do it any harm to have it all changed.
Post #337179 13th Jul 2015 10:47am
dhallworth
Well a box of goodies arrived from Dan this afternoon so I put the SC on the ramp in the workshop and set about giving it a good service.
I changed all 8 plugs, the Supercharger oil (not from Dan), the air filter, front and rear diff oils and the transfer box oil.
None of the plugs looked particularly bad and they were all the same colour. The ground electrode on some most of them was worn away on one edge. I've tried to take photo's of this but I'm not sure they've come out very well. All of the plugs were very tight to get out to the point where I was loosening them a bit and tightening them a bit to work them out through fear of damaging the thread in the cylinder head. They all came out and went back in without a great deal of fuss though. I'm positive they were the original plugs.
The Supercharger oil was changed as I'd bought the kit but hadn't got around to doing it so I thought whilst the engine cover was off I'd get it done, it's quite a straight forward job really once you've removed the big aluminium air intake the goes across the top. I think I've got a slight oil leak from something up there as it was a little damp. The old oil looked almost identical to the new stuff, it was just a tad darker.
The front diff oil and transfer box oil that came out looked fairly clean as well but they're replaced with nice fresh new oil.
The rear diff oil that came out was pretty horrid. You need 1.5 litres or thereabouts to change this so I'm going to order another 1 litre bottle from Dan and do another change on the rear diff in a couple of months just to make sure the old stuff is completely gone.
The only thing left on the "To Do List" is a gearbox oil change. I can't work out if I'm best doing a partial change myself or whether I should send it into Mackie Transmissions in Glasgow who are the local ZF agents and have advised they can do the filter and a mega flush on the system for the same price as I can buy the oil and filter from Dan. It's tempting to have it done as I know all the old oil will come out then but I've read mixed reports online and I can't help but worry if they'd use the right oil.
Anyway, the car is running beautifully now. It's probably the Placebo effect but it feels a touch smoother and it feels slightly quicker through the revs when you plant it. Thumbs Up
Post #337539 16th Jul 2015 1:22am
how many miles on the original plugs david? ... - .- -.
Post #337550 16th Jul 2015 8:24am
dhallworth
They had covered 90k, Stan.
Post #337553 16th Jul 2015 9:00am
