Home > Technical (L322) > Air Con Compressor
dhallworth
Air Con Compressor
I noticed the other day when I was on the lanes around home that there was a very slight whine from the SC at between 1000 and 2000rpm. Above that it either wasn't there or I couldn't hear it.
Today, whilst waiting for SWMBO to come out of Asda I noticed the same whine with the car stationary (was a bit of a relief as I now know it isn't gearbox or drive train).
I switched the air con off on the HEVAC panel and the noise disappeared. When coming up the country lanes home I noticed the noise appearing again so I turned the air con off again and it disappeared.
Has anyone else had problems with the air con compressor? Is it likely to be the compressor itself or just the clutch that's noisy? Are they available separately?
Post #337127 12th Jul 2015 10:16pm
Zirconblue
it might just be the belt is slipping. I'd check that first, if it's worn it might just be it's slipping when the air con puts a load on it.
Post #337137 12th Jul 2015 10:52pm
dhallworth
Thumbs Up Thanks for the advice. Will have a look at it.
Getting the fan and stuff off the front of it looks to be a right pain so it's not something I'm looking forward to! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #337139 12th Jul 2015 10:53pm
johnboyairey
These days a belt does not actually slip as it has a tensioner, this tensioner is a bearing with a mini gas shock absorber, set against a fixed position. and you set its tension, so that it maintains same tension as the belt wears -(a little) thus the belt(s) don't squeak. However, the bearing on the tensioner, can wear and whine, and they are much cheaper to replace than say the compressor. Had this exact thing happen on the missus' merc. Bearing and pulley was about £25 genuine.
If you you are able, you could just spray it a little with somepenetrating oil, (though it is a sealed bearing, but might offer some ingress) to see if it changes its 'tune' and diagnose it that way. Same on the compressor.
Post #337144 12th Jul 2015 11:59pm
crispy2
Australia 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Mine is making a similar AC related whine (car done 65,000 kilometers). I was more suspicious of the idler bearing than the ac compressor so I'll have a look at that after returning from 2 week caravan outing up north. '07 4.2 S/C
'13 X3M
Post #337147 13th Jul 2015 12:58am
Zirconblue
It's depends how shot the belt is, if they're really old they can become very worn and no long be able to grip the pulleys so start to slip. But it's true, you rarely find one that squeals like a pig on modern polyvee belts, but under load you can get them start to have more of a whine from them slipping ever so slightly.
Of course there are other possibilities, such as the pulley bearings, compressor bearings, tired tensioner spring etc. However the belt is easy to check, having a good visual check of it, you can see if it's worn out or not, hence i said start with that. You can also look for wear in the tensioner/idler pulleys, i've seen them with big tracks worn out of them, it doesn't do anything for tension.
Post #337153 13th Jul 2015 1:21am
Zirconblue
Getting the fan off isn't too hard really, although it's fiddly. Much easier with the holding tool for the water pump, but even that's not essential.
The most awkward part is getting the thread started when you put the fan back on, because it's difficult to hold it square while turning it.
Post #337154 13th Jul 2015 1:23am
Also bare in mind the abnormal temp at the moment and the fact your AC will be working extra hard so may sound a little different?
Post #337161 13th Jul 2015 5:17am
dhallworth
I think I've heard it a couple of times before the temperature got warm unfortunately.
Although I think it's me being very pernickety. I tried to record the noise and can't hear it and neither of my folks or SWMBO can hear it. Big Cry
Post #337176 13th Jul 2015 10:32am
