![]() | Home > Technical (L322) > Air Con Compressor |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
it might just be the belt is slipping. I'd check that first, if it's worn it might just be it's slipping when the air con puts a load on it. |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
These days a belt does not actually slip as it has a tensioner, this tensioner is a bearing with a mini gas shock absorber, set against a fixed position. and you set its tension, so that it maintains same tension as the belt wears -(a little) thus the belt(s) don't squeak. However, the bearing on the tensioner, can wear and whine, and they are much cheaper to replace than say the compressor. Had this exact thing happen on the missus' merc. Bearing and pulley was about £25 genuine.
| crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102
Mine is making a similar AC related whine (car done 65,000 kilometers). I was more suspicious of the idler bearing than the ac compressor so I'll have a look at that after returning from 2 week caravan outing up north. '07 4.2 S/C
It's depends how shot the belt is, if they're really old they can become very worn and no long be able to grip the pulleys so start to slip. But it's true, you rarely find one that squeals like a pig on modern polyvee belts, but under load you can get them start to have more of a whine from them slipping ever so slightly. Of course there are other possibilities, such as the pulley bearings, compressor bearings, tired tensioner spring etc. However the belt is easy to check, having a good visual check of it, you can see if it's worn out or not, hence i said start with that. You can also look for wear in the tensioner/idler pulleys, i've seen them with big tracks worn out of them, it doesn't do anything for tension. |
Getting the fan off isn't too hard really, although it's fiddly. Much easier with the holding tool for the water pump, but even that's not essential. The most awkward part is getting the thread started when you put the fan back on, because it's difficult to hold it square while turning it. |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Also bare in mind the abnormal temp at the moment and the fact your AC will be working extra hard so may sound a little different? |
I think I've heard it a couple of times before the temperature got warm unfortunately.
