Home > General > jacks..
Page 2 of 4 <1234>
Fox
Quote:
have you the jack's spec FOX?
Here it is:
http://www.machinemart.co.uk/shop/product/...l-garage-j
I have some in the workshop and with multiple daily use they last about three or four years.
Post #33808 26th Oct 2010 4:43pm
ta mate.. Thumbs Up ... - .- -.
Post #33809 26th Oct 2010 4:44pm
M44K TS
scarey wrote:
crikey thats a bit close to the van !!
looks like that jack does the job... Thumbs Up
btw, whats the reach on your jack?
Miles off that man! I usually park the car so close to the van that even with the mirrors folded in on the RR, there's about 1cm clearance against the side of the van, I suppose I do take up 2/3 of the drive space with my car and van, even more if I bring the Mini home. Twisted Evil
I'll check the specs on the jack too as off hand, I can't remember how high it goes.
Fox wrote:
The one Maak uses is perfect. I have the same. Thumbs Up
Who? Laughing [/pedantic mode] 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #33838 26th Oct 2010 5:56pm
Fox
Sorry, I was going by your reg plate/username. Embarassed
Post #33840 26th Oct 2010 6:09pm
hongkongphooey
Isle Of Man
I got a 2 1/2 tonne jack from Halfrauds at about £100, surprisingly a fair old effort to jack the old girl up!I only bought it as I was swapping out all the discs and pads too.
I did take the car into National Tyres to have the wheels ballanced up just recently (new 7 spoke 19's Rolling Eyes ) and the fitter asked me to raise the car to the off road setting? I'd have thought dropping it all the way down would have been better, but hey ho! At least the wobble stopped Smile
Post #33842 26th Oct 2010 6:43pm
thats interesting, i wonder why he said that.. ... - .- -.
Post #33843 26th Oct 2010 6:45pm
hongkongphooey
Isle Of Man
Yep, got me too. I'd of thought by lowering it, there would be less suspension travel using up the jacks travel, raising the car would just mean jacking for longer????
I'd didn't object too much in case I'd missed something completely obvious Whistle
Post #33849 26th Oct 2010 7:01pm
M44K TS
One bloke told me to put it in off road height with the hazards on and tailgate open when having one of my tyres resealed, apparently to let the car know it was about to be jacked up.
Fox - Mark not Maak Laughing 2006 Mercedes CLS
Post #33851 26th Oct 2010 7:08pm
hongkongphooey
Isle Of Man
Sounds like one of my dates Laughing
Post #33853 26th Oct 2010 7:14pm
Anytime i have had tyres or alloys changed at National thats what they do as Mark above has said .... Thumbs Up
Had a few changes in my time Laughing Laughing
Post #33854 26th Oct 2010 7:16pm
M44K TS
 2006 Mercedes CLS
Post #33856 26th Oct 2010 7:26pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I have a 48" Farm Jack for my Defender and hate using it as it could slip so easily if not very carefully set up, also FFRR would suffer severe panel damage trying to lift on that style of jack as the lifting leg would have to be right against the panels or the door open, there are also no suitable jacking points on L322 for the "Land Rover" peg that can be fitted to most utility Land Rovers for lifting them by the front or rear of the chassis with a farm jack. The 3t trolley is the best thing if you don't have a garage hoist like 47P2's
Scarey and Fox - the reasons for putting the car to offroad height 1) you are not having to use the jack to overcome the extension of the airstruts which are empty at access mode 2) if you lift with the suspension in access height you also confuse a lot of ride height sensors. The local Budget centre have trolley jacking of modern Land Rovers to a fine art.......... they learned the hard way the first L322 or D3 they had in for a tyre change........... they put the jack under the suspension compressor and putt the whole weight of the car on it to lift it! They follow the LR owners manual to the letter including using the wedge on the diagonally opposite wheel and putting the car into low box before they start jacking the car up 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #33869 26th Oct 2010 7:48pm
dan_uk_1984
When using a trolley jack you should lift as per the workshop manual. There are jacking points on the front and rear subframe in the center.
This also enabled you to use axle stands, which if you're doing work on tough components that need some elbow grease is a must.
Dan
Post #33874 26th Oct 2010 7:58pm
M44K TS
I find a windy gun takes out lots of the elbow grease Whistle 2006 Mercedes CLS
Post #33875 26th Oct 2010 7:59pm
tim thanks for the advice re the farm jack and the info on jacking the FFRR. Thumbs Up ... - .- -.
Post #33891 26th Oct 2010 8:16pm
Page 2 of 4 <1234>
